Transport Canada issues latest recalls - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: From the Street (//www.focuscanada.net/forum/forumdisplay.php?fid=19) +--- Thread: Transport Canada issues latest recalls (/showthread.php?tid=17871) |
Transport Canada issues latest recalls - Frost__2001 - 05-06-2010 Transport Canada issues latest recalls Ottawa, Ontario – Transport Canada has issued its latest recalls, which may affect some BMW, Acura, Ford, Toyota, Lexus, Volvo and Infiniti vehicles, and some Hercules and Toyo Nitto tires. 2010 BMW X5 Vehicles affected: 172 On certain vehicles, the front side marker lamps are not illuminated as required by the Canada Motor Vehicle Safety Standard, resulting in reduced visibility. Dealers will repair affected vehicles. 2010 Acura ZDX Vehicles affected: 605 On certain vehicles, the material covering the instrument panel may not be properly scored to allow the complete deployment of the passenger side airbag. In the event of a crash, the airbag will not deploy properly. Dealers will inspect the instrument panel skin and replace if necessary. 2009 Hercules Terra Trac SUV Units affected: 72 Certain tires may develop and exhibit tread chunking or cracking in the tread shoulder area, and tread chunks may separate from the tire. Dealers will inspect, replace and dispose of all affected tires. 2010 Toyo Nitto Dune Grappler Desert Terrain Units affected: 158 Certain tires may develop a crack in the upper sidewall. Under certain circumstances, a crack may lead to sudden loss of air. Dealers will inspect, replace and dispose of all affected tires. 2010 Ford Explorer 2010 Ford Explorer Sport Trac 2010 Ford Fusion Vehicles affected: 1,458 On certain vehicles, the manual seat recliner mechanisms may have gear plate teeth out of dimensional specifications, which could result in limited pawl to the gear plate tooth engagement, and create additional movement to the seat back. Dealers will replace the affected front seat manual recliner mechanism(s). 1998-2010 Toyota Sienna Vehicles affected: 140,000 On certain vehicles operated where road salt is frequently used, excessive corrosion of the spare tire carrier assembly cable may cause separation of the spare tire stowed under the vehicle. Dealers will repair affected vehicles. 2008-2010 Toyota Highlander 2008-2010 Toyota Highlander Hybrid 2007-2010 Toyota Tundra Vehicles affected: 4,774 On certain vehicles, if the Toyota optional accessory “tray-type” floor mat is not secured by the retaining hooks, or if it is placed on top of an existing floor mat, the tray-type mat could move forward and may interfere with the accelerator pedal. The manufacturer will notify owners to remove the tray-type floor mat and provide instructions on how to obtain a refund. 2010 Lexus GX460 Vehicles affected: 446 On certain vehicles, if driven through a sharp turn at high speed, the rear tires may loose traction and the vehicle may go in a sideways direction. Owners will be advised and dealers will reprogram the vehicle stability control software. 2010 Volvo XC90 Vehicles affected: 168 On certain vehicles, a manufacturing defect in the fuel pressure line may result in a fuel smell and/or fuel seepage. Since the fuel line is working under constant pressure, seepage may occur within a short period of time and eventually develop into a greater fuel leak. Dealers will inspect and, if necessary, replace the affected fuel pressure line. 2005-2007 Infiniti G35 Coupe 2005-2006 Infiniti G35 Sedan Vehicles affected: 9,474 On certain vehicles, the wire harness connecting the belt tension sensor (BTS) and the occupant detection sensor (ODS) control unit under the front passenger seat can experience relative movement, possibly caused by vehicle vibration or a passenger on the seat cushion. In certain instances, this may cause the pin and sleeve terminals in the connector to rub against each other, which could lead to a signal interruption from the BTS to the ODS control unit. If a signal interruption is detected, the passenger air bag would not operate, and the red supplement air bag warning light would flash and the amber front passenger air bag status light would illuminate. Dealers will repair affected vehicles. [/align] RE: Transport Canada issues latest recalls - Scorcher000 - 05-06-2010 Read the Lexus write up. Expect many of those to come in 2011 when All vehicals are required to have Active Suspension. Anf the Ford wirte up... Is that the Best Ford can F up lol RE: Transport Canada issues latest recalls - NefCanuck - 05-06-2010 Man, I'd like to know just how many Ford Fusions are part of that recall cause I don't think I've personally come across a car with manual front seat back adjustments. The cars I've seen are all power seatbacks ![]() Probably the Fusion S model (all five of them Ford ever made and sent up here ![]() NefCanuck RE: Transport Canada issues latest recalls - mo_focus - 05-06-2010 haha, i wanted to get a highlander but that was the only suv/car Toyota didnt give special pricing on. I wonder if this recall is going to change that ![]() |
