Suspension Question - Printable Version
+--- Thread: Suspension Question (/showthread.php?tid=17976)
Suspension Question - Chromey - 06-06-2010
I changed my Springs again... Issue Is, My front left strut Wont tighten, The Main Bolt just spins with the Shaft.
Is this a broken mount.?
RE: Suspension Question - ZTWsquared - 06-07-2010
(06-06-2010, 11:16 PM)Chromey Wrote: I changed my Springs again... Issue Is, My front left strut Wont tighten, The Main Bolt just spins with the Shaft.
You can stop the shaft from turning by putting the appropriate screwdriver or bit right into the top of the shaft - you can then use an open wrench to tighten the nut.
The shaft spinning is fairly normal - it's no indication of anything broken.
RE: Suspension Question - Chromey - 06-07-2010
might be what i forgot to do this time... LOL Ill check.
This is my 4th set of springs... I hate spring sag.
RE: Suspension Question - konafocuswrc - 06-09-2010
you will need to use allen key to stop shaft from spinning..
do not use hex, it will damage and you will end up using vice grip..
RE: Suspension Question - Chromey - 06-09-2010
(06-09-2010, 02:58 AM)konafocuswrc Wrote: you will need to use allen key to stop shaft from spinning..
Exactly What I forgot to do... All fixed now.
