coilovers - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: coilovers (/showthread.php?tid=18013) |
coilovers - gfxfocus - 06-13-2010 i drive a 07 zx5 and i just have a request to see pics of coilovers that have put into the back. jjust gotta check something to make sure before i install mine. RE: coilovers - hardk0re - 06-13-2010 rear end of 07's same as rear end of 02 svt's? RE: coilovers - GFXjamie - 06-13-2010 all rear ends suspension is the same and front is almost the same RE: coilovers - hardk0re - 06-13-2010 what pics/angles do you need? RE: coilovers - gfxfocus - 06-13-2010 just a pic of the setup whether it be with the wheel off or a view from behind the focus whatever you have. thanks RE: coilovers - GFXjamie - 06-13-2010 all the coilover is, is a springs with a adjuster sleeve in rear perch and a shock external unless you went with focus central rear coilover set up. the front will be a true coilover where coil is over the strut with an adjuster for height RE: coilovers - gfxfocus - 06-13-2010 i got custom coilovers from selex and im just wondering how coilovers look in the back |
