DRL fog lamp mod for '06-'07 - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: DRL fog lamp mod for '06-'07 (/showthread.php?tid=18159) |
DRL fog lamp mod for '06-'07 - arpaul15 - 07-07-2010 Just wanted to know how to do the DRL fog lamp mod for the 2006 model, as they have different relays/fuse setup for the fog lamps and drl i believe. I have seen how-tos for pre 2005 models, but they are different for 2006-2007. Please do post a link or instructions on how to go about with this mod. Thnx! RE: DRL fog lamp mod for '06-'07 - ZTWsquared - 07-07-2010 (07-07-2010, 01:57 PM)arpaul15 Wrote: Just wanted to know how to do the DRL fog lamp mod for the 2006 model, as they have different relays/fuse setup for the fog lamps and drl i believe. I have seen how-tos for pre 2005 models, but they are different for 2006-2007. Please do post a link or instructions on how to go about with this mod. I don't think you can do it ... IIRC on later Foci they used the same relay for high beams and fog lamps (instead of separate relays as in earlier years) ... unless you can jump the DRL circuit (R12) to a single connector on the High beam/fog light circuit (R5) but I've never heard of anyone doing that. Why not take your R5 relay out and post up a pic - someone might be able to figure it out. RE: DRL fog lamp mod for '06-'07 - Spinal - 07-08-2010 you can't make the fogs become the DRLs, but you can pull the DRL fuse so that you can just turn on the parking lights, or parking lights and fogs but not the headlamps. RE: DRL fog lamp mod for '06-'07 - ZX3_2NV - 07-08-2010 You can atleast with the MK1 focus my buddy with a Wagon did it some how with SVT fogs. RE: DRL fog lamp mod for '06-'07 - ZTWsquared - 07-08-2010 (07-08-2010, 01:28 AM)ZX3_2NV Wrote: You can atleast with the MK1 focus my buddy with a Wagon did it some how with SVT fogs. Oh yeah ... Mk 1's no problem ... jump the power from the DRL relay to the two points on the fog light relay - voila. But it's easy only because the fogs have their own relay. RE: DRL fog lamp mod for '06-'07 - arpaul15 - 07-08-2010 hmm yea...the fogs and high beams are in a single relay...i was looking at the system using a dealership repair manual...and seems like it MIGHTTTT be possible, however itll be complicated. Like i'll have to take individual wires , with fuses in between, and connect each one to the fog lamp/high beam connectors, with the actual relay being outside.... RE: DRL fog lamp mod for '06-'07 - Mystake - 07-09-2010 (07-08-2010, 02:05 PM)arpaul15 Wrote: hmm yea...the fogs and high beams are in a single relay...i was looking at the system using a dealership repair manual...and seems like it MIGHTTTT be possible, however itll be complicated. Like i'll have to take individual wires , with fuses in between, and connect each one to the fog lamp/high beam connectors, with the actual relay being outside.... do it up!.. as long as its safe to do RE: DRL fog lamp mod for '06-'07 - arpaul15 - 07-09-2010 (07-09-2010, 01:05 AM)Mystake Wrote:(07-08-2010, 02:05 PM)arpaul15 Wrote: hmm yea...the fogs and high beams are in a single relay...i was looking at the system using a dealership repair manual...and seems like it MIGHTTTT be possible, however itll be complicated. Like i'll have to take individual wires , with fuses in between, and connect each one to the fog lamp/high beam connectors, with the actual relay being outside.... lol I'm using a fuse in every little piece of wire I'm adding!! Don't wanna risk burning my car down for a lil drl fog lamp lol RE: DRL fog lamp mod for '06-'07 - konafocuswrc - 07-10-2010 if you are willing to do as i say, it can be done but fog switch is not going to work. disconnect socket goes to bulb and cable tie them away from moving parts. get 30/40 spst relay get enough 14~16ga.. connect -86 to ignition 12v(anything turns on when you turn key) -85 to chasis ground -30 to battery 12v, fuse in-inline(15a will be fine) -87 to each L+R fog light + -fog light - to ground again, fog switch is not controlling fiog light anymore.. RE: DRL fog lamp mod for '06-'07 - arpaul15 - 07-10-2010 Thanks dude, looks a lil more than just jumping wires lol. I'll try it out soon mostly or if someone could show me a it done on their car at the massive Monday meet. |
