Sunroof - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Sunroof (/showthread.php?tid=18303) |
Sunroof - CanadaSVT - 08-17-2010 The sunroof is acting up. Have to hold and let go of button just right to get the roof to open or close properly either tilting or opening all the way up and closing. Could be switch or out of alignment? Any fix for this? Thanks. RE: Sunroof - Scorcher000 - 08-18-2010 Check the tracks, there might be something on them not letting it open or close properly. Happened to me before RE: Sunroof - tetra - 08-18-2010 Not sure if your car has this, but my 2009 has a feature to "re-adjust" the sunroof by holding the buttons down. I forget the sequence, but it's in the manual. RE: Sunroof - CanadaSVT - 08-18-2010 Thanks. I'll give it a look. RE: Sunroof - OAC_Sparky - 08-19-2010 Roof Opening Panel Motor Initialization Updating Roof Opening Panel Motor Initialization WARNING: The roof opening panel anti-trap function will not operate during the updating roof opening panel motor initialization procedure. Make sure that the roof opening panel opening is free of all foreign material. Failure to follow this instruction may result in personal injury. NOTE: This procedure should only be carried out when the roof opening panel motor has not been disconnected. NOTE: The roof opening panel alignment must be carried out prior to carrying out roof opening panel motor initialization. For additional information, refer to Roof Opening Panel Alignment in this section. Operate the roof opening panel control switch to the up/close position until the roof opening panel is in the fully open/vent position. Release the roof opening panel control switch. Operate the roof opening panel control switch to the up/close position and hold for 30 seconds until there is a small movement (approximately 2 mm) and the roof opening panel motor stops. Release the roof opening panel control switch. Operate the roof opening panel control switch to the up/close position again within 0.5 seconds until the roof opening panel stops (one complete cycle). Initial Roof Opening Panel Motor Initialization WARNING: The roof opening panel anti-trap function will not operate during the updating roof opening panel motor initialization procedure. Make sure that the roof opening panel opening is free of all foreign material. Failure to follow this instruction may result in personal injury. NOTE: This procedure must be carried out when installing any roof opening panel motor or roof opening panel. NOTE: The roof opening panel alignment must be carried out prior to carrying out roof opening panel motor initialization. For additional information, refer to Roof Opening Panel Alignment in this section. Operate the roof opening panel control switch to the up/close position. Release the roof opening panel control switch. Operate the roof opening panel control switch to the up/close position again within 0.5 seconds until the roof opening panel stops (one complete cycle). Erasing Roof Opening Panel Motor Initialization NOTE: The erasing procedure is to be carried out only when the roof opening panel motor has been detached from the roof opening panel. NOTE: This procedure must be carried out before installing a previously used roof opening panel motor. Connect the roof opening panel motor electrical connector. Operate the roof opening panel control switch to the up/close position until the roof opening panel motor stops. Release the roof opening panel control switch. Operate the roof opening panel control switch again to the up/close position and hold for 30 seconds. With the roof opening panel control switch held, the roof opening panel motor will rotate in one direction. Release the roof opening panel control switch. Operate the roof opening panel control switch to the down/open position. If the roof opening panel motor does not rotate, the erasing procedure has been carried out successfully. If the roof opening panel motor rotates (with the roof opening panel control switch in the down/open position), repeat the procedure. RE: Sunroof - Scorcher000 - 08-19-2010 Very Detailed ![]() RE: Sunroof - CanadaSVT - 08-19-2010 (08-19-2010, 01:46 AM)OAC_Sparky Wrote: Roof Opening Panel Motor Initialization Thanks Sparky. I'm on afternoons so I'll have to wait until the weekend to try this out, unless I let the wife use the Marauder ![]() RE: Sunroof - CanadaSVT - 08-23-2010 Works normally now, thanks! |
