Hatch Release not cooperating - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Hatch Release not cooperating (/showthread.php?tid=18400) |
Hatch Release not cooperating - chromehorse - 09-21-2010 The hatch release on my '00 wagon stopped working a couple of weeks ago. I finally got around to checking it out and now i need help. The release won't work by both remotes or the dash button. All the fuses are good and when i went to check for power at the plug for the release mechanism, i had one pin with battery voltage and nothing else, even when the buttons are pressed. Is it possible the remotes activate the ground? What else should i be checking? RE: Hatch Release not cooperating - NOS2Go4Me - 09-21-2010 Have you checked all of your fuses? Everything related to the door locks and anything specifically labelled for the hatch? Sorry man, I JUST got back into a Focus (had two before), and I'm admittedly a little rusty. Rule of thumb is check all of the fuses that could possibly have anything to do with that, and then check your wire loom going into the hatch to see if you have any broken wires. RE: Hatch Release not cooperating - Focus man. Focus. - 09-21-2010 I would check the wires running from the body to the hatch. Through the rubber tube if you know what I mean. Good place to start anyways. RE: Hatch Release not cooperating - sonic_mikey - 09-21-2010 I have a few buddies who work at ford and they need to rewire the loom bundle to the hatch regularly. Does your 3rd brake light work and washer nozzle spray still? RE: Hatch Release not cooperating - OAC_Sparky - 09-22-2010 If you have power at the latch mechanism, check continuity of the ground. A toony says the ground wire is broken or loose, probably at the loom between body and hatch as others have said. RE: Hatch Release not cooperating - Scorcher000 - 09-25-2010 My X GF's 2000 Sedan had a problem like that. Her mom kept hitting the dash untill it did work lol. So I'm not sure about your sitch but I'm a firm believer in smash it untill it works. But that didn't work on my door handles Good luck. RE: Hatch Release not cooperating - 243jimb - 10-01-2010 (09-21-2010, 01:12 PM)chromehorse Wrote: The hatch release on my '00 wagon stopped working a couple of weeks ago. I finally got around to checking it out and now i need help. The release won't work by both remotes or the dash button. All the fuses are good and when i went to check for power at the plug for the release mechanism, i had one pin with battery voltage and nothing else, even when the buttons are pressed. Is it possible the remotes activate the ground? What else should i be checking? |
