Car Problem.. - Printable Version
+--- Thread: Car Problem.. (/showthread.php?tid=1845)
Car Problem.. - konafocuswrc - 03-17-2009
other than 2 oxygen sensors related code, i got p0401..
cleand egr valve and was fine for 4 days and got this instead..
p1405..
was going to get dpfe sensor but realized 2 hose goes from dpfe to egr valve was loose..
1 hose was disconnected..put it back on but can be pulled easy with almost 0 force..
so with alll these, my car runs crap..hesitate and stall..
now car overheats and realized no fan gets triggered..
when idling, it overheats..if i keep rpm up, temp goes back to normal but as soon as sitting idling, temp goes up..
with ac on, still no fan gets activated..
all the wiring was fine..resistor pack might be shot but thinking 2 relays might also be the problem..
i don't know what to do now..
Car Problem.. - konafocuswrc - 03-19-2009
fixed overheat problem..
relay was busted..
put regular SPDT relay and fixed problem..
i heard fan going once and haven't heard since then, but temp never goes over anymore..
tried to change oxygen sensor but i need to engine and trans to do whole swap first..
