Can I lube the shift cables? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Can I lube the shift cables? (/showthread.php?tid=18532) |
Can I lube the shift cables? - duckcanuck - 11-05-2010 Hi, the 5-speed shift lever on my 2003 Zetec wagon (104,000 km) is getting a little notchy. I wonder if this is because the shift cables are getting dirty/dry. Is there a way to lube these cables, or otherwise free them up? Thanks. Bob the Duck Canuck RE: Can I lube the shift cables? - sonic_mikey - 11-06-2010 most likely coming out of adjustment, hit this site up on how to correct it for free http://www.focushacks.com/index.php?modid=49&ht=Adjusting%20Shifter%20Linkage%20without%20the%20special%20tool RE: Can I lube the shift cables? - duckcanuck - 11-06-2010 (11-06-2010, 08:13 AM)sonic_mikey Wrote: most likely coming out of adjustment, hit this site up on how to correct it for free Thanks for this pointer. I read over it, and I have a couple of questions: - after pushing in the orange clips to release them, it says to move the shift arms to the neutral position. What is that position? Is it just straight up and down? - then to re-lock the adjusters, do you just pry them back up with something like a screwdriver blade? Thanks again, Bob the Duck Canuck RE: Can I lube the shift cables? - Benzin - 11-07-2010 after I had done the undercoating with Krown, for the first two days the gearshift was extremely smooth but then it returned to normal. it would be nice if we could lube them and stay like that longer. RE: Can I lube the shift cables? - sonic_mikey - 11-07-2010 (11-06-2010, 12:31 PM)duckcanuck Wrote:(11-06-2010, 08:13 AM)sonic_mikey Wrote: most likely coming out of adjustment, hit this site up on how to correct it for free just like the schematic, straight down and yes u have to pop the orange taps back up with whatever you can RE: Can I lube the shift cables? - pankaj86775 - 11-25-2010 whatever you do ... do not click on the link in my sig as I am a self-loathing, scab-infested, pustulent scammer |
