Yemeni Toner Cartridge cellphone bomb - may NOT have been able to detoinate at all - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Off Topic (//www.focuscanada.net/forum/forumdisplay.php?fid=16) +--- Thread: Yemeni Toner Cartridge cellphone bomb - may NOT have been able to detoinate at all (/showthread.php?tid=18550) |
Yemeni Toner Cartridge cellphone bomb - may NOT have been able to detoinate at all - paolo - 11-11-2010 http://www.bunniestudios.com/blog/?p=1351 There are so many things wrong with the picture of that cellphone circuit board in the picture published bye the media. The website above explains why it would not have detonated at all, and could have been exaggerated by the Americans. Secondly, another website confirmed what cellphone was used at this site: http://www.f-secure.com/weblog/archives/00002057.html What boggles my mind, if someone really wanted to blow up a plane, they would not leave so many clues, there is an IMEI, which is tracable, a SIM card which is tracable, and the cellphone with NO ANTENNA would get no signal, especially since most phones would not get signal anyway in an airplane. I know i am not an expert, but you dont have to be one to know the cellphone is missing a few key components this leads many to think its a way of the US government trying to play out something bigger than it really is. Its a shame the Canadian government is playing along. More: Of course, I don’t have access to the ware itself so I must apply my judgment to the guesses, but I believe it’s fairly safe to say that it’s a Nokia 6120c or very closely related model (the entire 612x family has motherboards that are basically identical sans minor changes for specific regional or carrier variants; see the wikipedia page for the Nokia 6120 family). I managed to dig up the original service manual schematics for the Nokia 6120c. There are some very curious features about the preparation of the cargo bomb package. First of all, the phone motherboard only has two wires (plus perhaps a ground strap) attached to it. I’m presuming at least one of the wires is for a battery voltage, assuming the return current is going through the metal case via the middle screw. If this were, for example, a trigger mechanism for something, then presumably the other wire is for the trigger signal. What makes this a little bit odd, then, is the lack of an antenna. If you look at the schematics for the device, there is a set of four leaf connectors at the top of the motherboard, X7550, X7551, X7552, and X7555 (would be on the rear right side in the photo taken by the press), which need to come in touch with an antenna for any reception worth a damn. I don’t see evidence of an antenna attached to these from the press photo, and if there was it would be pretty close to the large ground plane presented by the metal case. The sensitivity of the radio would be fairly bad, making it unreliable at best as a remotely activated trigger. One may presume that this is simply because the creator of this package was not skilled in electronics; if that’s the case then I feel a little bit safer since the “bad guys” don’t know how to build a reliable remote bomb trigger out of a cell phone. However, another possibility is that the motherboard didn’t even have a SIM card in it, and as a result this is just a cheeseball version of the “alarm clock” that you would see in, for example, a “movie bomb”. If they simply attached a wire to the vibrator motor terminals or the ringer/speaker connector, and set a wake-up alarm a couple days later, this would function fairly decently as a time-delay device to activate some mechanism. It’s not hard to find a used mobile phone that doesn’t work as a phone, but still works well enough to set an alarm, although if I were looking for a simple mechanism to just act as a trigger I wouldn’t pick something that has an IMEI (International Mobile Equipment Identity) or other serial numbers that can be traced through a supply chain. Then again, let’s hope that the “bad guys” aren’t smart enough to realize that mobile phones make poor event triggers if you were hoping for some kind of anonymity. A little more browsing of the latest press releases note that there was a SIM card in the device, so presumably this was intended to receive a call to detonate the package. Glad to hear the sender of the package doesn’t know much about RF circuits and antennas. Granted, a phone can still receive a signal without an antenna, but the reliability would be poor; you’d need to be much closer to a base station so you have a high chance of failure in executing the plot. And SIM cards contain a wealth of traceable information. At the very least, someone has to call the phone to set off the trigger. If the phone is intercepted and the SIM card is put into a normal phone, the plotter would be unpleasantly surprised to find that it’s the FBI answering (and looking at your caller ID), instead of a bomb going off. Furthermore, scanning packages for suspicious devices becomes a lot easier, because you can just use a handheld RF scanner to look for radio waves in key frequency bands coming out of boxes that you would otherwise expect to be inert. In other words, a box with an active phone on the inside would advertise its presence in a detectable way to the outside world through its RF signature. Of course, all wild speculation based on one low-res photo of a phone motherboard… RE: Yemeni Toner Cartridge cellphone bomb - may NOT have been able to detoinate at all - NOS2Go4Me - 11-12-2010 So, aside from the fact you just turned yourself into a "person of interest" for CSIS, what does it matter whether the bomb-that-should-have-exploded actually was capable of exploding or not? Some jackhole terrorist tried to blow s**t up and failed. Personally, I'd like to drive over him / her in my truck. Repeatedly. I don't care what tech they used. I don't care if it was viable or not. They tried to perform a cowardly, spineless attack on a bunch of innocent people. They should, in turn, die very slowly and painfully as a reminder that they're terrorists and they deserve it for what they had attempted to do. RE: Yemeni Toner Cartridge cellphone bomb - may NOT have been able to detoinate at all - darkpuppet - 11-12-2010 A couple thoughts: If the people were stupid enough to think that they put in a SIM card so the phone could receive a call, but didn't think of the range of the antenna, couldn't we go one magnitude of stupidity less and assume that maybe they thought the SIM card was required to activate the phone enough to use the alarm function? And we're assuming a lot of things that are true in North America. You can trace via the SIM card, you can trace via the IMEI easily enough. But that's assuming that neither are stolen, grey market, or cloned -- or in Yemen -- where stolen, cloned and grey market electronics are more the norm than the exception. I'm not saying that it's not possible that a clandestine operation to be involved, but you're short-selling governments with a lot more resources to fake these things properly to what appear to be half-baked conspiracy theories. RE: Yemeni Toner Cartridge cellphone bomb - may NOT have been able to detoinate at all - 02ztsian - 11-12-2010 It is too obviously fake to be considered as a legitimate threat. The real interesting part is that they probably put together this laughable fake bomb to test the waters for the real McCoy to come later. Also by sending it out of Yemen and thus focusing all of the interest around the region it may divert attention from a real bomb being sent out from another part of the world. |
