FS European Spec Tails - Printable Version
+-- Forum: Classifieds (//www.focuscanada.net/forum/forumdisplay.php?fid=5)
+--- Forum: Sell Items (//www.focuscanada.net/forum/forumdisplay.php?fid=26)
+--- Thread: FS European Spec Tails (/showthread.php?tid=18974)
Pages: 1 2
FS European Spec Tails - xXCMGXx - 04-21-2011
For Sale: European Spec Focus Tails no wiring or pigtails
Price: $130 obo
[Image: DSC01559.jpg]
RE: FS European Spec Tails - ZTWsquared - 04-21-2011
(04-21-2011, 12:29 PM)xXCMGXx Wrote: For Sale: European Spec Focus Tails no wiring or pigtails
Price: $130 obo
Hatch or wagon ... do they include the bulb holders?
GLWS.
RE: FS European Spec Tails - xXCMGXx - 04-21-2011
Hatch, I dont have the bulb holders
RE: FS European Spec Tails - xXCMGXx - 04-29-2011
BUMP!!
RE: FS European Spec Tails - reldridge - 04-29-2011
Pics? I might have a buyer...
RE: FS European Spec Tails - xXCMGXx - 04-30-2011
i added a picture tell your friends!
RE: FS European Spec Tails - xXCMGXx - 05-04-2011
bumpity bump!
RE: FS European Spec Tails - xXCMGXx - 07-20-2011
bump!!!!! OBO lets go
RE: FS European Spec Tails - ZTWsquared - 07-21-2011
(07-20-2011, 10:58 PM)xXCMGXx Wrote: bump!!!!! OBO lets go
PM sent
RE: FS European Spec Tails - 2MuchDub4U - 11-07-2012
Still have these????
RE: FS European Spec Tails - ZTWsquared - 11-07-2012
(11-07-2012, 09:10 AM)2MuchDub4U Wrote: Still have these????
He doesn't - I do LOL.
RE: FS European Spec Tails - 2000zx3sct - 11-07-2012
what do you have to do to make those work on a focus? im confused when people on FF say they dont have the harness.
RE: FS European Spec Tails - GFXjamie - 11-08-2012
these put turn signals and brakes in the tail lights, instead of reverse and brake/turn together. requires some modification to the wiring harness, along with plugs and bulbs to match the lights. They are different then the USDM bulbs
RE: FS European Spec Tails - ZTWsquared - 11-08-2012
(11-08-2012, 07:25 AM)GFXjamie Wrote: these put turn signals and brakes in the tail lights, instead of reverse and brake/turn together. requires some modification to the wiring harness, along with plugs and bulbs to match the lights. They are different then the USDM bulbs
yup - not only are the bulbs different (P21 type) the bulb holders are different and require different connectors to plug into the holders. Until I found a harness for sale I was resigned to the fact that I had to more or less create my own.
The issue, as Jamie alluded to, is that the turn signal function is now a different bulb than the brake light function and within the housing there is no reverse light - so altering the output from the stock harness is also required.
There are a lot of ways to do that, I chose not to cut and connect at the PCM and instead will be using a 2 to 3 adaptor - sort of the opposite of what you might use to connect a three-bulb car to a 2-bulb trailer.
What ken said, except for 00-01, there is no gem module and so you just cut one wire by driver door sil, and then tap into 3rd brake light for brake signal and splice in all your goodies. There are numerous write ups but 02+ is different as I did the conversion on taylors 00
(11-08-2012, 11:31 AM)GFXjamie Wrote: What ken said, except for 00-01, there is no gem module and so you just cut one wire by driver door sil, and then tap into 3rd brake light for brake signal and splice in all your goodies. There are numerous write ups but 02+ is different as I did the conversion on taylors 00
yeah I had to cut / splice wires at the GEM for the euro tails on my 07 wagon. makes sense now why Ford went with the combined brake/turn bulb on the 02+ sedan.
didn t realize it was so simple for 00-01
RE: FS European Spec Tails - 2000zx3sct - 11-08-2012
Ahh I see , good to know for the future if I ever get my hands on some. Thanks
RE: FS European Spec Tails - drunkinmonkey - 11-09-2012
i have a set that i havent installed cause i didnt know the bulb holders or pig tails
RE: FS European Spec Tails - GFXjamie - 11-09-2012
bulb holders/pig tails can be sourced from VW, i believe from a VW bettle tail lights. There are numerous sources of this info, both FJ and FF have it.
