SS brake lines? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: SS brake lines? (/showthread.php?tid=19415) |
SS brake lines? - Mystake - 08-21-2011 Recommendations on what brand to get? Planning the use to be for a bit of autocross. My front ones are showing wear from rubbing so they need to be replaced. I've seen recommendations for one brand, then recommendations for another. IDK what to get... any help? Thanks, RE: SS brake lines? - Oscar The Grouch - 08-21-2011 Russell RE: SS brake lines? - sonic_mikey - 08-21-2011 russell, I haz, they r win ![]() RE: SS brake lines? - Mystake - 08-22-2011 Have they lasted? I don't want to have to change them again in the near future. RE: SS brake lines? - Oscar The Grouch - 08-22-2011 SS brake lines should last much longer than oem rubber ones. RE: SS brake lines? - sonic_mikey - 08-22-2011 iv had them on almost 2 years and they still look like they just came out of the box RE: SS brake lines? - Flofocus - 08-22-2011 As I mentioned in another thread, be carefull with these in the winter, keep them clean. The salt builds up int hem and they will start to frey after years of use. My mechanic showed me some on a WRX that were starting to frey and failed the guys safety because of it. RE: SS brake lines? - sonic_mikey - 08-25-2011 The russel lines actually have a rubber/plastic sheathing over them from end to end, keeps them lookin good and all that garbage out RE: SS brake lines? - Mystake - 08-25-2011 (08-22-2011, 11:29 PM)Flofocus Wrote: As I mentioned in another thread, be carefull with these in the winter, keep them clean. The salt builds up int hem and they will start to frey after years of use. My mechanic showed me some on a WRX that were starting to frey and failed the guys safety because of it. (08-25-2011, 06:33 AM)sonic_mikey Wrote: The russel lines actually have a rubber/plastic sheathing over them from end to end, keeps them lookin good and all that garbage out I had read that "modern" or, newer SS lines all have that rubber/plastic sheathing. Thanks for bringing it up though, nate! RE: SS brake lines? - Mystake - 08-26-2011 http://www.steeda.ca/ford-focus-parts/2.0L-Zetec/braking/Brake-Lines/Russell/693250/ Steeda has em for 83$ originally the website had em listed for 135 but I called it in, turns out its cheaper than their american sites too. I'm (y) about it RE: SS brake lines? - Mystake - 09-01-2011 I placed the order late Thursday evening/night It shipped Tuesday around noon... but FedEx got it here today by 2! Focus should be track ready by tomorrow ![]() RE: SS brake lines? - CanadaSVT - 09-02-2011 Hi. I was going to suggest KVR Performance out of Ottawa. The lines on my dd Marauder are mint after 6 years. http://kvrperformance.com/ Which ones did you end up getting? RE: SS brake lines? - Mystake - 09-03-2011 The ones I linked to from Steeda, I'll keep KVR in mind though I have a lot of brake fade to deal with so I'll want to change that up sooner than later RE: SS brake lines? - ZTWsquared - 09-03-2011 (09-03-2011, 06:03 AM)Mystake Wrote: The ones I linked to from Steeda, If fade is a problem, then make sure you do a full brake fluid flush to all four corners when you do your brake lines, and consider upgrading your fluid. RE: SS brake lines? - drunkinmonkey - 09-03-2011 my work custom makes ss brake lines...any colour hose any colour fittinggs.. mine are all blue ss ![]() RE: SS brake lines? - Mystake - 09-03-2011 jeez you guys are all too late to the party... if these ones fail then I'll send you a PM or something lol... |
