engine cutting off - Printable Version
+--- Thread: engine cutting off (/showthread.php?tid=19427)
engine cutting off - rnzo86 - 08-24-2011
hey guys has anyone ever had the issue, when driving the engine just shuts off, it's happened to me 4 times already. when I was driving going 50-60 kph the engine just turned off. Any idea off the cause??
RE: engine cutting off - drunkinmonkey - 08-24-2011
Grounding problem.....check all the grounds for the motor
RE: engine cutting off - Mystake - 08-25-2011
could be alternator - was told when mine was replaced that it was creating surges which were causing the car to shut off.
RE: engine cutting off - konafocuswrc - 08-25-2011
also could be spark plugs or wires.
RE: engine cutting off - hardk0re - 08-26-2011
happened to me a few times in the 01 Grey Focus, happened a few times it was the ground point beside the battery on the fender side. Then again just befmore I melted my engine wiring harness, and that was a maf harness that shorted out on the EGR tube.
RE: engine cutting off - Focus man. Focus. - 08-26-2011
Fuel pump?
