HELP! No electrical power at all - Printable Version
+--- Thread: HELP! No electrical power at all (/showthread.php?tid=19494)
HELP! No electrical power at all - WuNgUnSVT - 09-17-2011
Car has sat over the winter, battery unhooked....kept on periodic charge.
Putting car back together, hooked up battery, no lights (going by interior dome light/map lights).
Charger is hooked up to car/battery now, reading 25%
Volt meter shows over 12V
Nothing!
Checked both main power fuses, they are okay...
Absolutely no power to car...
What can it be??
RE: HELP! No electrical power at all - Scorcher000 - 09-17-2011
Dead Battery
RE: HELP! No electrical power at all - WuNgUnSVT - 09-17-2011
Vokt meter says otherwise...and its on a charger
Put the Focus wagon battery in the SVT....NOTHING!!
Still no power anywhere...
WTF!
Sad
RE: HELP! No electrical power at all - ZTWsquared - 09-17-2011
(09-17-2011, 04:24 AM)WuNgUnSVT Wrote: Put the Focus wagon battery in the SVT....NOTHING!!
WTF!
Sad
If the battery's good then I would think the next thing to check is your primary ground and power connections ... start at the battery and just follow the leads.
Okay...feeling a little bit stupid right now...and I knew it had to be something simple.
Putting the wagon battery back in the wagon, I notice TWO leads going to the + terminal.
SVT had ONE hooked up...
Starting tearing out the battery box and intake, and lying right there trapped under the Volant airbox was the other lead...
Connected and rocking!!!!
RE: HELP! No electrical power at all - konafocuswrc - 09-17-2011
lol that happens once in a while.
It was a huge relief finding the missing lead! I was thinking blown ECU or broken/pinched + lead...
RE: HELP! No electrical power at all - kc focus - 09-18-2011
Does your headlights work? if so your battery has power and if not you have to start with a bad connection with or bad battery... Check main fuse or main relay..
RE: HELP! No electrical power at all - WuNgUnSVT - 09-19-2011
(09-18-2011, 07:13 AM)kc focus Wrote: Does your headlights work? if so your battery has power and if not you have to start with a bad connection with or bad battery... Check main fuse or main relay..
Ummm...your a bit late. but thanks!
