Rear de-frost - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: How To's (//www.focuscanada.net/forum/forumdisplay.php?fid=24) +--- Thread: Rear de-frost (/showthread.php?tid=19616) |
Rear de-frost - DUBL02 - 11-02-2011 Hey guys, can someone tell me if the de-froster on the rear window can be repaired or do i need to replace it? Or if i get a complete tailgate from the wreckers what years are compatible with my '03 ZX5, thanks. RE: Rear de-frost - buzz2.0 - 11-02-2011 i do know of a repair kit you can get, its like a copper paint to fix the defroster if one of the lines are broken...but if thats actually the problem...i do not know... RE: Rear de-frost - ZTWsquared - 11-02-2011 (11-02-2011, 06:08 AM)DUBL02 Wrote: Hey guys, can someone tell me if the de-froster on the rear window can be repaired or do i need to replace it? Or if i get a complete tailgate from the wreckers what years are compatible with my '03 ZX5, thanks. All years and both ZX3 and ZX5 will work. RE: Rear de-frost - castone - 11-02-2011 I'm not sure if you can repair the defrost but any hatch from 00-07 will fit. Try here car-part.com RE: Rear de-frost - moon111 - 11-03-2011 Taft's in Brighton, Ontario. They're in it for the scrap metal prices, let people pick away anyways. Prices very good. RE: Rear de-frost - DUBL02 - 11-03-2011 Thanks for the replies, does anyone know how to disconnect the wiring to remove the hatch? Are the connectors behind the trim panel? Thanks. RE: Rear de-frost - muttsnutts - 11-24-2011 Do what I did, get the kit, you mix some glue and activator put it on the tab fix it to the glass then paint it with the stuff that comes with the kit, I did mine after the tab came off on the glass.Worked perfectly Dont know if thats your problem. Seems a lot of work to change out the hatch if thats all it is RE: Rear de-frost - muttsnutts - 12-05-2011 (11-24-2011, 02:21 PM)muttsnutts Wrote: Do what I did, get the kit, you mix some glue and activator put it on the tab fix it to the glass then paint it with the stuff that comes with the kit, I did mine after the tab came off on the glass.Worked perfectly Dont know if thats your problem. Seems a lot of work to change out the hatch if thats all it isThis is what I used RE: Rear de-frost - DUBL02 - 12-08-2011 Thanks, i did pick up some of this to repair it but some a$$ saved me the trouble by rear ending me a couple of weeks ago and my car was written off. The good thing is i picked up another ZX5 in better shape and the rear defrost works, and also the a/c. RE: Rear de-frost - 02_svt_guy - 12-08-2011 (12-08-2011, 12:42 AM)DUBL02 Wrote: Thanks, i did pick up some of this to repair it but some a$$ saved me the trouble by rear ending me a couple of weeks ago and my car was written off. The good thing is i picked up another ZX5 in better shape and the rear defrost works, and also the a/c. that works! RE: Rear de-frost - muttsnutts - 12-08-2011 That works out even better lol RE: Rear de-frost - NOS2Go4Me - 01-21-2012 (12-05-2011, 08:21 AM)muttsnutts Wrote:(11-24-2011, 02:21 PM)muttsnutts Wrote: Do what I did, get the kit, you mix some glue and activator put it on the tab fix it to the glass then paint it with the stuff that comes with the kit, I did mine after the tab came off on the glass.Worked perfectly Dont know if thats your problem. Seems a lot of work to change out the hatch if thats all it isThis is what I used I've gotta find one of those to fix Subsonic with. CT? PartsSource? RE: Rear de-frost - muttsnutts - 01-21-2012 (01-21-2012, 01:40 AM)NOS2Go4Me Wrote:(12-05-2011, 08:21 AM)muttsnutts Wrote:(11-24-2011, 02:21 PM)muttsnutts Wrote: Do what I did, get the kit, you mix some glue and activator put it on the tab fix it to the glass then paint it with the stuff that comes with the kit, I did mine after the tab came off on the glass.Worked perfectly Dont know if thats your problem. Seems a lot of work to change out the hatch if thats all it isThis is what I used Either same place right? CT or P Source |
