Quick question - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Quick question (/showthread.php?tid=19770) |
Quick question - 07focus_st - 01-26-2012 Will the svt cluster well I wanted the face plates wil it work on my st focus? RE: Quick question - Oscar The Grouch - 01-26-2012 Nope... tried that on my 07, no workie. RE: Quick question - SL8RZZX3 - 01-26-2012 I believe it does work, but you have to change to location of the wires on the connection that goes into the cluster. Or cut and hack in an SVT cluster harness (which is harder and messier) RE: Quick question - GFXjamie - 01-27-2012 The face plate may work, but that's it. I am using gauge face intended for 00-04. Some of the side lights are not correct but otherwise it is the same RE: Quick question - Frost__2001 - 01-27-2012 hmm so if I got an SVT odo it would work in a stock 2002 zx3? RE: Quick question - Oscar The Grouch - 01-27-2012 Face plate doesn't match up with RPM and Speedo on 05-07. Different motors, different setup... Not worth it IMO. RE: Quick question - SL8RZZX3 - 01-27-2012 (01-26-2012, 11:57 AM)07focus_st Wrote: Will the svt cluster well I wanted the face plates wil it work on my st focus? You can't change the face plates, but if you look into the wiring you should be able to swap the entire cluster (01-27-2012, 12:38 AM)Frost__2001 Wrote: hmm so if I got an SVT odo it would work in a stock 2002 zx3? Yes they will direct swap clusters from 00-04, but you will need to add a power inverter from Speedhut or similar |
