CEL and new hesitiation issues - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: CEL and new hesitiation issues (/showthread.php?tid=19774) |
CEL and new hesitiation issues - 02_svt_guy - 01-27-2012 Ok.. So where to start. first things first I have a CEL on and it has to do with my o2 sensor(downstream i believe). it has been on for a while and i have replaced it twice now. I am thinking my Cat is on the way out or already gone as i am starting to noticing driveability issues when the car warms. It jerks and hesitates at lower RPM's and miss's at idle. More recently i have noticed i cannot go more then half throttle or so in any gear as it goes into a full on misfit state of hesitation. Is this an issue with my Cat? i replaced the plugs last winter with e3 plugs so they are not the issue. Does anyone know if what i am experiencing is directly related to the cat or could it be a possible vacuum leak or a common problem? any help would be nice before i start throwing money at 02 sensors and a Bolt on Cat section. Also it is def not my Clutch. When the car is cold it is fine. Thanks, Brandon RE: CEL and new hesitiation issues - Flofocus - 01-27-2012 doubt its an issue with the svt model but I would still check.... http://www.focuscanada.net/forum/showthread.php?tid=13248 I would also still take a look at the plugs and wires just to be 100% sure. RE: CEL and new hesitiation issues - 1seensvt - 01-27-2012 crack in the coil pack RE: CEL and new hesitiation issues - 02_svt_guy - 01-28-2012 Thanks guys. I have a warm garage to do some much needed tlc on the SVT this weekend... So i will check the connection for the coil. Ive been running Screamin Demon coil and live wires for about 60k now so maybe it is starting to retire. I will keep u posted. Would a extremely dirty airfilter or MAF cause this? RE: CEL and new hesitiation issues - Flofocus - 01-28-2012 it could, I know when my Ebay air filter on my turbo would get wet, I would get similar issues. I'd check the coilpack/wires 1st though since its right there.... RE: CEL and new hesitiation issues - garythewolf - 01-28-2012 the cat maybe plugged,,,we had to chang ours to pass the e-test RE: CEL and new hesitiation issues - stupica1 - 01-28-2012 def check coil pack, wires and sparks first. mine had the same issue, I swapped all three components plus replaced my vacuum hose at the back of the intake and it cleared right up! RE: CEL and new hesitiation issues - NOS2Go4Me - 02-02-2012 Yup, also the leads going into the coil pack (if roughly the same as the Zetec setup). Doubt it's the cat as a miss is ignition or fuel (normally ignition), so a cat would be too far removed from the issue. |
