Can the '05-'07 washer nozzles be re-aimed? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Can the '05-'07 washer nozzles be re-aimed? (/showthread.php?tid=19816) |
Can the '05-'07 washer nozzles be re-aimed? - 05ST - 02-17-2012 Hi I'm a new Focus owner; here's my question: I have a 2005 ST and as I drive mainly highway I find the washers spray too low on the windshield. Can they be aimed higher, or are there revised parts available? A quick look didn't reveal anything obvious. 05ST RE: Can the '05-'07 washer nozzles be re-aimed? - Scorcher000 - 02-17-2012 They can just be cleaned with a tooth pick. But now I think you may be able to move then too. Not sure good luck. RE: Can the '05-'07 washer nozzles be re-aimed? - 2009SEL - 02-22-2012 05 Not sure about Focii, but in other vehicles, I would insert a needle (which helps clean it out) and use it as leverage and place the spray where I wanted. I found midpoint between the lowest and highest part of the windshield best; a good combination of street and highway driving. Also, are you sure your pump is giving you max. pressure? Just my 2C RE: Can the '05-'07 washer nozzles be re-aimed? - 05ST - 02-23-2012 (02-22-2012, 08:51 AM)2009SEL Wrote: 05 The pump seems ok; the spray is strong. just a little low at highway speeds. 05ST RE: Can the '05-'07 washer nozzles be re-aimed? - moon111 - 02-23-2012 Maybe a little off topic, but in Finland, the squirter is called a 'pissapoika', which translates to pissing boy. The top windshield wiper fluid brand-name is called Superpiss. This sounds a little like going to the doctor and saying it hurts when I do this and the doctor says, "Then don't go like that." Maybe driving under 160km/hr would help? |
