How do you stop clear coat peeling on wheels? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: How do you stop clear coat peeling on wheels? (/showthread.php?tid=19914) |
How do you stop clear coat peeling on wheels? - duckcanuck - 04-01-2012 I bought a used set of factory 17 inch SES wheels (2009). They still look pretty good, but I noticed that some of the clear coat is peeling. I googled this, and only found people who said you have to strip the wheel completely, and recoat. Is there a way just to stop it getting any worse? Bob the Duck Canuck RE: How do you stop clear coat peeling on wheels? - 1seensvt - 04-01-2012 i would try a couple of coats of wax but a refinish will probably be the only thing that will stop it so good luck to u RE: How do you stop clear coat peeling on wheels? - castone - 04-01-2012 If it's only the clear coat and not the actual paint you could wet sand then respray more clear coat on them. I know dupli-color sells the wheel paint in a clear at Canadian Tire. RE: How do you stop clear coat peeling on wheels? - Flofocus - 04-03-2012 you can try wet sanding it and re-clearing as castone suggested, but I havent seen a job like that come out looking good ever. best is to strip clean and start from scratch, waxing wont do anything at all. |
