Hooking UP LEDS to battery with a switch. - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Hooking UP LEDS to battery with a switch. (/showthread.php?tid=20085) |
Hooking UP LEDS to battery with a switch. - 2000zx3sct - 05-25-2012 Hey , im trying to install LEDS to my car battery to a switch. Can someone on here give me an outline on what to do.... or if someone has done this before on there focus let me know. RE: Hooking UP LEDS to battery with a switch. - konafocuswrc - 05-25-2012 what are you exactly doing? adding underbody leds?? RE: Hooking UP LEDS to battery with a switch. - 2000zx3sct - 05-25-2012 (05-25-2012, 03:45 PM)konafocuswrc Wrote: what are you exactly doing? Just basic LED strips , got them from Walmart haha. I have the wires through the car already .... But I can't figure out how to run a switch, im thinking that I need a resistor or i read somewhere that I need to run it to the fuse box. RE: Hooking UP LEDS to battery with a switch. - darkpuppet - 05-26-2012 you should run it through a fuse, but you can get by with an inline fuse. What voltage are the strips rated for? If you bought them at wallmart, and they're 12v, you likely won't need a resistor as it'll be in the light strip. If not, you'll need to put an inline resistor. a very simple calculator for figuring out what resistor you would need can be found by googling -- or here RE: Hooking UP LEDS to battery with a switch. - 2000zx3sct - 05-26-2012 (05-26-2012, 12:05 AM)darkpuppet Wrote: you should run it through a fuse, but you can get by with an inline fuse. What voltage are the strips rated for? If you bought them at wallmart, and they're 12v, you likely won't need a resistor as it'll be in the light strip. Hey , i ended up just taping into the daytime runner fuse , "low beam" i guess. I think i was overthinking things... i didnt bother running a switch inside to much of a hastle. thanks for the replies! RE: Hooking UP LEDS to battery with a switch. - Scorcher000 - 05-26-2012 Day time is no good. That runs the bulbs at a lower voltage. In return that actually increases the heat in the wire and may cause damage. Find and empty fuse slot, run a line from the battery to the fuse box and then fuse it up and there you glow. haha get it |
