? About rear SVT brake parts... - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: ? About rear SVT brake parts... (/showthread.php?tid=20394) |
? About rear SVT brake parts... - SL8RZZX3 - 07-25-2012 I'm going to work on piecing together a rear SVT brake set-up.... I have spindles, calipers, dust shields from a SVT part out... What else do I need to complete it? New rotors and pads obviously! But what do I need as far as e-brake cables and any thing else I might be missing? Thanx in advance! Part numbers would be greatly appreiciated RE: ? About rear SVT brake parts... - Oscar The Grouch - 07-25-2012 Brake lines. RE: ? About rear SVT brake parts... - castone - 07-25-2012 Caliper brackets, flex lines(the ST lines are easier to install and maintain ![]() flex line brackets, e-brake cable. RE: ? About rear SVT brake parts... - ZTWsquared - 07-25-2012 I'm quite sure that the following part numbers came in the SVT conversion kit that Ford Racing used to make: Parking brake assembly: 1m5z2a603ab Rear caliper brackets and bolts: 2m5z2b582aa Hose bracket right: 5S4Z2082A and left 5S4Z2082B Brake hose: 5s4z2282ba hub retaining nut: ys4z3b477aa There's other things like grease caps and spindle bolts but if you have the spindle you probably got those too. You may want to take this opportunity to change out the brake hardware - look for kits H5084 and 13119 (both are for the D886 pad) and finally you may want to swap out the bleeders. Good luck with the install. RE: ? About rear SVT brake parts... - SL8RZZX3 - 07-26-2012 Thanx guys!! I'm going to get SS lines So I think I just need the e-brake cables |
