Idle Help - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Idle Help (/showthread.php?tid=20460) |
Idle Help - 2000zx3sct - 07-31-2012 So i have installed my new 65 mm throttle body courtesy of SL8RZZX3 , Im having trouble setting the idle , I have turned it right down and it still sits just about 1000 rpm . Im thinking that i need a different TPS in order to fix this , but not totally sure . Just thought i would ask on here before i go any further. Any help appreciated. RE: Idle Help - SL8RZZX3 - 07-31-2012 What SCT tuner do you have? Can you make any adjustments that way? RE: Idle Help - 2000zx3sct - 08-01-2012 (07-31-2012, 10:42 PM)SL8RZZX3 Wrote: What SCT tuner do you have? Can you make any adjustments that way?It's an xcal 2 , I was reading a thread on focus fanatics and another guy had the same problem , he said he put a tps that was for a manual trans and it fixed the problem RE: Idle Help - 2000zx3sct - 08-01-2012 Alright so I got a new tps from the wreckers and she purres like kitten. Can't believe the difference that the tb makes has a lot of power off the line now. RE: Idle Help - SL8RZZX3 - 08-01-2012 Sweet I'm glad you got it working! Did you end up porting the intake mani? Or just bolted it on? RE: Idle Help - 2000zx3sct - 08-01-2012 (08-01-2012, 02:04 PM)SL8RZZX3 Wrote: Sweet I'm glad you got it working! i ported the intake , and i got rid of the ridge that was in the tb. Im really happy with the car right now. she chirps the tires between when shifting from 1st to second. ![]() |
