Swapping seat heater question - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Swapping seat heater question (/showthread.php?tid=20516) |
Swapping seat heater question - Platinum6316 - 08-21-2012 Has anyone swapped the seat heater element into a fabric seat? I'm removing the leather seats from my ZTW and installing the fabric ones from my old SE. I'd like to peel back the fabric and install the heater, but I'm afraid that might cause damage to the fabric. Any ideas, thoughts, or "DON'T DO IT!!" please let me know. RE: Swapping seat heater question - ZTWsquared - 08-21-2012 (08-21-2012, 09:53 AM)Platinum6316 Wrote: Has anyone swapped the seat heater element into a fabric seat? AFAIK it's a replaceable part - I had one replaced once under warranty. If I could find my Ford DVD I'd look up the re and re instructions - but it's disappeared into the depths of the abyss that is my garage. RE: Swapping seat heater question - Platinum6316 - 08-22-2012 It should be fairly easy to move, just remove the seat covering and remove the elements, and do the reverse on the good seats. At least that's what I think ... I'll disassemble my leathers soon to see, and let you know. RE: Swapping seat heater question - ZTWsquared - 08-22-2012 (08-22-2012, 10:10 AM)Platinum6316 Wrote: It should be fairly easy to move, just remove the seat covering and remove the elements, and do the reverse on the good seats. Sounds right ... BTW - in order to refit the covers nice and tight it will help to have a hogring pliers - it's still ancient tech when it comes to Focus seat construction. RE: Swapping seat heater question - Platinum6316 - 08-22-2012 I plan on acquiring said pliers. ![]() Just make my life so much easier. I'll take pics and let you know how it works out RE: Swapping seat heater question - Platinum6316 - 08-23-2012 My other question is: will it damage the fabric covering, since I've only found heaters with leather seats. RE: Swapping seat heater question - ZTWsquared - 08-23-2012 (08-23-2012, 10:45 AM)Platinum6316 Wrote: My other question is: will it damage the fabric covering, since I've only found heaters with leather seats. No - they did offer heated seats with fabric in some models / model years. RE: Swapping seat heater question - duckcanuck - 08-24-2012 (08-23-2012, 10:55 AM)ZTWsquared Wrote:(08-23-2012, 10:45 AM)Platinum6316 Wrote: My other question is: will it damage the fabric covering, since I've only found heaters with leather seats. Correct. Both my 2005 SES and my 2010 SE have heaters in fabric seats. Bob RE: Swapping seat heater question - Platinum6316 - 08-29-2012 Perfect, thanks guys! RE: Swapping seat heater question - Mystake - 08-29-2012 just to add, my 03 zx5 had heated cloth seats (which I then swapped out for heated leather seats) RE: Swapping seat heater question - Platinum6316 - 09-02-2012 Partially disassembled one of the leather seats to try for the heater element. The hog-rings are in odd places and the fabric on the element pad was disintegrating, so decided to not continue with this plan. |
