Motor mounts - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Motor mounts (/showthread.php?tid=20558) |
Motor mounts - adamzx5 - 08-25-2012 So its time to get some new motor mounts , the stock ones just couldnt take it anymore :p. Which is the best way to go? ( do them all) and what brand? RE: Motor mounts - GFXjamie - 08-26-2012 depends what you want. Are you looking for a performance aftermarket or a OEM replacement? Unless you are seriously in need of vibrations, i would only suggest doing the rear mount with a poly aftermarket mount. You can do the other 2 aswell, but it will be stiff all together. As for aftermarket mounts, i use the ones FSWerks sells VF engineering. RE: Motor mounts - adamzx5 - 08-26-2012 Well I was going to do the passenger side because its the broken one , and since im already in there i might as well replace the other ones. Can you notice a differnce with the stiffer rear mount? RE: Motor mounts - GFXjamie - 08-26-2012 big difference because it is the torque mount that stops the motor from moving when you jam on the gas to shift gears. You wont get that clunk then you powershift into second either RE: Motor mounts - konafocuswrc - 08-26-2012 i have all aftermarket 3 motor mounts and girls love my car. RE: Motor mounts - adamzx5 - 08-26-2012 (08-26-2012, 02:16 PM)konafocuswrc Wrote: i have all aftermarket 3 motor mounts and girls love my car.Lmfao , that would be nice alot less work. |
