Ssbc drum to disc - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Ssbc drum to disc (/showthread.php?tid=20647) |
Ssbc drum to disc - jtdanks - 09-20-2012 Any feed back on the ssbc drum to disc conversion? http://www.amazon.com/SSBC-A161-1-Rear-Drum-Conversion/dp/B001EEW78Y/ref=sr_1_2?s=automotive&ie=UTF8&qid=1348103567&sr=1-2&ymm=2003%3Aford%3Afocus&keywords=2003+Ford+Focus+SSBC+Drum+to+Disc+Brake+Conversion+Kits RE: Ssbc drum to disc - GFXjamie - 09-20-2012 Looks to be a conversion for solid rear axle vehicles. Looks to be 5 bolt as well. I'm just looking on my phone tho but can't see a specific application RE: Ssbc drum to disc - jtdanks - 09-20-2012 It says it fits a 2003 focus, I'm not sure if of order it off amazon lol probably right from ssbc just curious on people's thoughts http://www.autoanything.com/brakes/77A5498A3716488.aspx Here's another one RE: Ssbc drum to disc - ZTWsquared - 09-20-2012 (09-20-2012, 11:54 AM)jtdanks Wrote: It says it fits a 2003 focus, I'm not sure if of order it off amazon lol probably right from ssbc just curious on people's thoughts The pic is just one of those generic pics - the SSBC website confirms the fitment for 2000-2007 Focus. SSBC makes pretty good stuff from what I've heard (never purchased any of their product though due to high cost) but there are a couple of things to consider: 1. According to the SSBC website 17" rims are required. Now the rotor specs appear to be exactly SVT (12" dia x 1" thick) which suggests you could get away with 16" as you can with SVT brakes (even the fronts which are closer to 13") ... but they may use a different caliper or caliper placement bracket. If you have 17s then not an issue. 2. You may want to confirm replacement part numbers and check out their cost. It could be that generic rotors and pads will fit, but you never know. What you want to find out is the FMSI number for each ... FMSI is a standardized number system for brake parts and crosses all lines between makes and models. Otherwise it seems to be a good option, albeit an expensive one, to replace the Ford Racing kit. RE: Ssbc drum to disc - jtdanks - 09-20-2012 I do have 17s waiting to be mounted and I sent ssbc and email yesterday asking a few questions so I can try and find out more when they reply |
