Heater Core! - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Heater Core! (/showthread.php?tid=20803) |
Heater Core! - Gravter - 10-18-2012 Well, I'm not sure if it's really it, but I think my heater core is leaking! My windows fog up on the inside but I can't really smell anything. I don't see any leaks in the cabin either. Anything else I should check? How hard or EASY is it to change the heater core? I'm hoping it won't require me to take it to the shop. I've changed one in my old '83 Mustang years ago. Thanks for your help! RE: Heater Core! - ZTWsquared - 10-18-2012 (10-18-2012, 09:12 AM)Gravter Wrote: Well, I'm not sure if it's really it, but I think my heater core is leaking! The fogging up certainly suggests water/moisture in the cabin, but IIRC a leaking heater core would dump coolant which you would definitely smell. Do you have any leaks into the cabin - perhaps a wet smell after a car wash or rain? Do you sweat profusely LOL? Replacing is by my standards definitely a DIY job - but according to the manual it looks to be a few hours.
RE: Heater Core! - Gravter - 10-19-2012 Holly crap! Those are a lot of steps to remove the core! Damn!!! I will have a closer look to see if there is any moisture in the cabin and no, I don't sweat so much! lol. Thanks RE: Heater Core! - Lucster1000 - 10-19-2012 Have you checked your A/C? I had the same problem until I recharged my A/C, now my windows never fog up. RE: Heater Core! - GFXjamie - 10-19-2012 +1 for moisture, check the spare tire well too. We have had a lot of rain lately in southern ontario. Make sure all your windows are up too. I've had rears left down a 1/4 inch without realizing for days RE: Heater Core! - reldridge - 10-19-2012 The Mustang would have been a lot easier. I know, I've done it on my '84. ![]() -remove glove box -remove access panel -under hose clamps -remove heater core. reverse ![]() Do you smell the sweet smell of antifreeze in teh car? RE: Heater Core! - Gravter - 10-21-2012 No, thats just it, I don't smell the usual prestone smell! I will have another look today and see if I find any moisture on the carpet or trunk. One thing I did notice, it seems to be worst, a lot worse, when I go from "defrost" position to half defrost/feet position! Wondering if it has something to do with my "air re-circulation" control! Thanks for all your input! RE: Heater Core! - Gravter - 11-26-2012 Hmmm, I finally had time to check out if I had a leaky core yesterday. Well, I did not find a leak, but what I do think is happening, as I mentioned in another post, I was thinking about the "fresh air" damper. When I looked behind the glove box yesterday, I noticed the damper was open, as in recirculating in cabin air! My controller was not set to that! So, now I have to figure out was is wrong with it. Either dead motor/actuator or fuse or whatever! For now, I will be clamping it closed so that it takes in fresh air only! I'm going for a drive soon, so I will see if that was it! ![]() RE: Heater Core! - ZTWsquared - 11-26-2012 (11-26-2012, 01:59 AM)Gravter Wrote: Hmmm, I finally had time to check out if I had a leaky core yesterday. Well that would certainly cause the problem you described - good catch, never heard of that happening before. |
