Transmission leak- minor, 2005 ZX5 - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Transmission leak- minor, 2005 ZX5 (/showthread.php?tid=20920) |
Transmission leak- minor, 2005 ZX5 - scimdarren - 12-26-2012 This is a bit of a generic question.On the passenger side, the driveshaft ends up as a solid shaft as it enters the standard transmission. It is leaking here (nothing major). Would this be a seal that could be replaced in situ, any ideas as to what could cause this leak? Thanks RE: Transmission leak- minor, 2005 ZX5 - hardk0re - 12-27-2012 There should just be a seal there, its not a cheap seal but its not overly priced either. IIRC $50 something. They are just rubber seals, not bearings + seals so they wear out easily. A worn out CV could possibly cause excess vibration/play and wear it out faster... |
