Heat Shields - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Heat Shields (/showthread.php?tid=21014) |
Heat Shields - hardk0re - 03-01-2013 Finally my heat shield under the car has let go, it is the one just under the passenger seats. I remember reading that it was OK to just remove it, anybody do this without adverse effects? Or should I simply try and bolt it back up with some pieces of metal or large washers? RE: Heat Shields - adamzx5 - 03-01-2013 I tried to re attach it with big washers and it just fell off again. Just rip it off i have have had nothing bad happen after it has been removed. RE: Heat Shields - drunkinmonkey - 03-01-2013 i took all mine off. if your overlly concearned you can spray some bed liner under there RE: Heat Shields - hardk0re - 03-01-2013 Good stuff time to cut it off. RE: Heat Shields - NoiSeeVT - 03-01-2013 I think mine have been gone for years. I had them repaired a few times under warranty but with no luck. |
