steering wheel removal help - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Appearance (//www.focuscanada.net/forum/forumdisplay.php?fid=21) +--- Thread: steering wheel removal help (/showthread.php?tid=21126) |
steering wheel removal help - drunkinmonkey - 04-11-2013 hey guys i plan on changing me steering wheel out in the near future, and was wondering - how do you get the airbag cover off?? RE: steering wheel removal help - Oscar The Grouch - 04-11-2013 Two bolts in behind on either side in the back. Make sure you remove the battery! RE: steering wheel removal help - drunkinmonkey - 04-11-2013 (04-11-2013, 10:37 PM)Oscar The Grouch Wrote: Two bolts in behind on either side in the back. Make sure you remove the battery! thank you sir!! no special tricks to remove the airbag or the wheel itself? RE: steering wheel removal help - Oscar The Grouch - 04-12-2013 it may have like a little clip on the bottom. The plugs are a bit of a bitch tho underneath. |
