For Sale: Aurasound NS10-513-4A 10" Sub - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Classifieds (//www.focuscanada.net/forum/forumdisplay.php?fid=5) +--- Forum: Sell Items (//www.focuscanada.net/forum/forumdisplay.php?fid=26) +--- Thread: For Sale: Aurasound NS10-513-4A 10" Sub (/showthread.php?tid=21369) |
For Sale: Aurasound NS10-513-4A 10" Sub - WuNgUnSVT - 08-19-2013 Great unit...great sound. No longer have a car... Has to go! Mount this in a ported box (or a larger sealed box) to the specs of the manufacturer, and you will surely be impressed. This is a sound quality piece...(will perform best in a ported enclosure of about 1.45 cubic feet, with a 3" x 10.5" port.) Clean, accurate, well performing reproduction of sub-frequencies. And at a great price! Visually, you can see some styrofoam stuck to it, and the soft rubber grill face shows a bit of wear, but the cone, surround and overall finish are in perfect shape. $100 + shipping or meet for pick-up (I'm in Muskoka) zzwungunzz@gmail.com Nominal Diameter . . . . . . . . . . . . . . .10 inches (254 mm) Nominal Impedance (Z) . . . . . . . . . . 4 ohms Sensitivity, 1W/1m (E) . . . . . . . . . . . 84 dB @ 200 Hz Power Capacity, RMS (Pe) . . . . . . . . 200 W Power Capacity, Peak . . . . . . . . . . . 800 W Frequency Range (-10dB) . . . . . . . . Fo - 4 kHz Minimum Impedance . . . . . . . . . . . . 5 ohms Voice Coil Diameter . . . . . . . . . . . . . 51.3 mm Voice Coil Winding Length (h) . . . . . 12 mm Voice Coil Number of Layers (n) . . . . 4 Voice Coil Former Material . . . . . . . . Kapton Voice Coil Wire Composition . . . . . . Copper Magnetic Material . . . . . . . . . . . . . . Neodymium radial Stray Flux Shielding . . . . . . . . . . . . . Inherent Magnetic Gap Depth (He) . . . . . . . . 32 mm Cone Material . . . . . . . . . . . . . . . . . Cast Aluminum Surround Material . . . . . . . . . . . . . . Injection molded rubber Polarity, Outward Motion . . . . . . . . . Positive voltage on (+) terminal Net Weight . . . . . . . . . . . . . . . . . . . . 4.5 kg Thiele / Small Parameters Resonant Frequency (Fo) - Fs . . . . . 29 Hertz Voice Coil DC Resistance - Re . . . . . 3.04 ohms Total Q - Qts . . . . . . . . . . . . . . . . . . 0.34 Mechanical Q - Qms . . . . . . . . . . . . 9.4 Electrical Q - Qes . . . . . . . . . . . . . . 0.35 Equivalent Volume of Air - Vas . . . . . 53.6 L Radiating Piston Area - Sd . . . . . . . . 346 cm Electrical / Mechanical Parameters Flux Density x Length - BL . . . . . . . . 12.2 Tesla-meters Compliance - Cms . . . . . . . . . . . . . . 318 mm/N Total Mass - Mms . . . . . . . . . . . . . . 95.5 grams ![]() ![]() ![]() RE: For Sale: Aurasound NS10-513-4A 10" Sub - WuNgUnSVT - 08-21-2013 Bump... RE: For Sale: Aurasound NS10-513-4A 10" Sub - WuNgUnSVT - 09-01-2013 Bump up.... For Sale: Aurasound NS10-513-4A 10" Sub - WuNgUnSVT - 10-07-2013 $75 takes it... Can be made to easily fit the SVT sub-box. RE: For Sale: Aurasound NS10-513-4A 10" Sub - WuNgUnSVT - 06-26-2014 Bump! I'm in the K-W area....$50 Come and get it! ![]() RE: For Sale: Aurasound NS10-513-4A 10" Sub - WuNgUnSVT - 11-01-2014 Bump........... |
