Driver side headlight low beam not working - Printable Version
+--- Thread: Driver side headlight low beam not working (/showthread.php?tid=21929)
Driver side headlight low beam not working - Lucster1000 - 10-16-2013
My driver side low beam stopped working the other day but both my high beams work. From what I understand it's a single bulb for the head lights so ok not sure how my high beams work but low beam dosnt, does anyone know a fix for this?
RE: Driver side headlight low beam not working - muttsnutts - 10-16-2013
(10-16-2013, 09:22 AM)Lucster1000 Wrote: My driver side low beam stopped working the other day but both my high beams work. From what I understand it's a single bulb for the head lights so ok not sure how my high beams work but low beam dosnt, does anyone know a fix for this?
Double filament bulb. Change the bulb first
RE: Driver side headlight low beam not working - Bailey8100 - 10-19-2013
Just use a test light to examine for power at the connect first then perform back again from there. A "multimeter" can provide outcomes. It reveals power but there is not enough present to mild a light bulb.
ava-tieman.com
RE: Driver side headlight low beam not working - muttsnutts - 10-20-2013
Jeez its not rocket science Just change the bulb
Driver side headlight low beam not working - Lucster1000 - 10-20-2013
It was just the bulb, I was unaware that a dual filament bulb can burn out like that, it is the first car I have owned with a dual filament headlights. I thought it was my wiring harness I have heard that the low beam wiring can burn out or a bad ground.
RE: Driver side headlight low beam not working - bawxcar - 10-21-2013
My 05 was notorious for blowing the low beam, almost kn a monthly basis. Unless I pulled the DRL fuse of course ;-)
