CV Joints and Axle Extension on Passenger side for 2002 Automatic Transmission - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: How To's (//www.focuscanada.net/forum/forumdisplay.php?fid=24) +--- Thread: CV Joints and Axle Extension on Passenger side for 2002 Automatic Transmission (/showthread.php?tid=22003) |
CV Joints and Axle Extension on Passenger side for 2002 Automatic Transmission - ErnessW - 12-27-2013 Well here I am after completely removing a junk engine from a 2002 Focus and replacing it with a used engine. After doing all that, you'd think I could reinstall the passenger side axle and axle extension into the transmission. Well, so far I can't. Oh the axle is easy to insert into the wheel area but the extention will not go all the way into the transmission, no matter how much I wiggle it around. Go figure. Any one got any suggestions? . CV Joints and Axle Extension on Passenger side for 2002 Automatic Transmission - GFXjamie - 12-27-2013 Rubber mallet on the carrier bearing and tap into place. Don't beat on it though. I usually put shaft into tranny first also RE: CV Joints and Axle Extension on Passenger side for 2002 Automatic Transmission - Scorcher000 - 12-29-2013 I actually had this problem as my slid out on me and I tried to put it back in. Do what Jamie said and use a soft rubber mallet and it did the trick for me but don't be rough on the seals, splines or threads. |
