Used Rims, Tires and Springs - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Classifieds (//www.focuscanada.net/forum/forumdisplay.php?fid=5) +--- Forum: Sell Items (//www.focuscanada.net/forum/forumdisplay.php?fid=26) +--- Thread: Used Rims, Tires and Springs (/showthread.php?tid=222) |
Used Rims, Tires and Springs - Scorcher000 - 03-08-2010 These were my rims and tires. Tire are bald and rims a lil rough but still very good. ****Asking $300 Cash**** Includes 3 X 17X7 Avanti Racing 108mm 40+ Offset 18 LBS (2 X Used 1 x New) 17X7 Avanti Racing 108mm with hub rings (4 Mounted On Tires In Picture) General exclaim UHP 215/40ZR17 25% Left Used Apex Lowering Springs Roughly 30,000KM Paint Wear Spring Still Strong Asking $80 Unpainted Cash Asking $100 Painted Cash An APEX® Sport Spring kit easily replaces the standard springs on your car. It will usually lower the car by 30-40 mm. Not only will this improve your cars' handling, response and grip, but will add that extra touch of style that will make your car look different from the rest of the crowd. The ride will be a little firmer, say sportier, but never too harsh. Used Rims And Tires - ZTWsquared - 03-08-2010 Scorcher000,Mar 7 2010, 08:01 PM Wrote:These were my rims and tires. Tire are bald and rims a lil rough but still very good.Are these the ones in your sig? Edit: n/m - I can see they aren't ... so: Make / model? Size / offset? Weight? Centre caps and hub rings included? Is "a lil rough" just curb rash or something more significant? Used Rims And Tires - Scorcher000 - 03-08-2010 Ya, they are. I'll fix the post sry just was rushed. Used Rims And Tires - ZTWsquared - 03-08-2010 Scorcher000,Mar 7 2010, 09:36 PM Wrote:Ya, they are. I'll fix the post sry just was rushed.Sorry John ... we were posting at the same time ... so if these are 18s I'll have to say "good luck" as they won't work for me. Used Rims And Tires - drunkinmonkey - 03-08-2010 are you finally gonna drop it ow with the money you get for the wheels haha why you seeling what rims did you get to replace??? free bump Used Rims And Tires - fatphocus - 03-08-2010 drunkinmonkey,Mar 8 2010, 12:26 AM Wrote:are you finally gonna drop it ow with the money you get for the wheels haha says in his sig :P MSR 085 Black/Chrome Lip 18" Wheels edit: and i agree, lower it!! lol Used Rims And Tires - Scorcher000 - 03-08-2010 The fronts are already lowered. The rears... um the rear lca bolt is spining with the bushing and Ford doesn't sell the bushing with out the CA. So I'm waiting on Jamie to order up some adjustable LCA's then the rear will be low. Used Rims And Tires - castone - 03-08-2010 Scorcher000,Mar 8 2010, 01:43 PM Wrote:The fronts are already lowered. Why not buy some energy suspension bushings? That way you can just cut out the old ones. Energy Suspension BTW Good luck with the sale! Used Rims And Tires - Scorcher000 - 03-09-2010 castone,Mar 8 2010, 07:54 AM Wrote:Scorcher000,Mar 8 2010, 01:43 PM Wrote:The fronts are already lowered. If I can't ge the arms for a good deal then i'm going that route. Thanx Used Rims And Tires - Focus man. Focus. - 03-09-2010 They didn't have to remove my rear lower control arms to install my springs. Whats up with that? Used Rims And Tires - Scorcher000 - 03-09-2010 I'll explain at the meet. Used Rims And Tires - GFXjamie - 03-09-2010 you have to lower the control arm and drop the spring to put in rear springs unless using a inner springs compressor which is less than ideal. remove the bolt holding in one side of the arm to drop it down. had this problem on niks car and had to replace both control arms. cost was around 330$ for arms and another 10$ for hardware. not fun. now if more people join in the group buy for LCA's then we can get john lowered finally! if not... well then i guess he will b less baller Used Rims And Tires - ZTWsquared - 03-09-2010 GFXjamie,Mar 8 2010, 03:22 PM Wrote:you have to lower the control arm and drop the spring to put in rear springs unless using a inner springs compressor which is less than ideal. remove the bolt holding in one side of the arm to drop it down. had this problem on niks car and had to replace both control arms. cost was around 330$ for arms and another 10$ for hardware. not fun. now if more people join in the group buy for LCA's then we can get john lowered finally! if not... well then i guess he will b less baller Wow ... not to threadjack or anything, but I can do 2 new Ford OE upgraded LCAs plus 8 new bolts and nuts, and new adjuster cams, for 245 CAD plus taxes. And yes - those inner spring compressors are the s***s - I borrowed one from Partsource for my mechanic to use and he gave up on it ... in the end I decided I wanted the heavier duty LCA from the 2009 Focus and bought them anyway. Used Rims And Tires - Mystake - 03-10-2010 can you PM me individual pictures of each rim? Used Rims And Tires - Scorcher000 - 03-10-2010 Ya, I'll do them today. And I'll try to do some vid. They will be ckleaned up and balanced for you too if you want them. They currntly sit at my cousins shop. Used Rims And Tires - Scorcher000 - 03-11-2010 Sry, never got around to taking pics or vid. Though you'll also get 3 extra rims and a set of Spline nuts too. So thats 7 rims 16 spline nuts 4 hub rings, and 4 passible tires on the 4 of the rims Used Rims And Tires - Mystake - 03-11-2010 Scorcher000,Mar 10 2010, 09:40 PM Wrote:Sry, never got around to taking pics or vid. Though you'll also get 3 extra rims and a set of Spline nuts too. So thats 7 rims 16 spline nuts 4 hub rings, and 4 passible tires on the 4 of the rims are all 7 rims the same? RE: Used Rims, Tires and Springs - Scorcher000 - 06-07-2010 Bump New Price, Items and Details RE: Used Rims, Tires and Springs - Scorcher000 - 06-12-2010 Sold Delete ASAP |
