For Those Who Use Ford Oil Filters - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: For Those Who Use Ford Oil Filters (/showthread.php?tid=2303) |
For Those Who Use Ford Oil Filters - Crazirich - 11-29-2008 If you haven't been told yet or found out Ford is obsoleting the FL-2005 filter used on the Zetec engine.. replaced by the FL-400-S. Yes it will work, and the price might be a bit better, but the FL-2005 has a anti drain back valve in it... so if you desire check your local dealer for OLD stock since they do not make them ANYMORE For Those Who Use Ford Oil Filters - reldridge - 11-29-2008 I've been using the FL-400s for awhile with no issue. No need to panic... For Those Who Use Ford Oil Filters - hardk0re - 11-29-2008 I've used the equivalent k&n of the FL-400's without the lock. I haven't had any issues, running boosted even for quite some time. For Those Who Use Ford Oil Filters - Crazirich - 11-29-2008 I HAVE NO ISSUES.... Just letting those who use the right stuff listed know whats going on... For Those Who Use Ford Oil Filters - zx5power - 11-29-2008 they valve is there so if theres a problem it will protect the engine not using it does not make sense ... protect the investment For Those Who Use Ford Oil Filters - Crazirich - 11-29-2008 THE flow back valve is there to keep the oil in the filter so its not a dry start up each time you cold start with an empty oil filter For Those Who Use Ford Oil Filters - faster_than_u - 12-01-2008 so why are they doing this? they are getting rid of a good filter for a crappier one? |
