How-to Program New Keyless Door Lock - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: How To's (//www.focuscanada.net/forum/forumdisplay.php?fid=24) +--- Thread: How-to Program New Keyless Door Lock (/showthread.php?tid=2454) |
How-to Program New Keyless Door Lock - hanserus - 10-28-2008 Would someone knowledgeble in this area please be kind to post some information on how this is done? How-to Program New Keyless Door Lock - konafocuswrc - 10-28-2008 oh i thought this is actual how to.. found this on focaljet.. Programming Procedure - AKA Relearn 00-02 1. Close all doors and fasten the seat belt to ensure conflicting chimes do not sound during programming. 2. Turn the ignition lock form OFF (2) to ON (3) at least 4 times in 6 seconds. 3. Switch off the ignition. Now the control module has entered the "learning mode" for 10 seconds. This mode is indicated by a chime. 4. While the control module is in the "learning mode", press and hold one of the buttons of the remote transmitter until a chime sounds. This indicates a new transmitter code has been successful programming, another 10 seconds "learning mode" is automatically entered, up to a maximum of four times. Another transmitter can now be programmed (repeat step 4). 5. The system will leave the "learning mode" after starting the ignition, if no new transmitter is programmed during the 10 seconds, or if 4 remotes have been programmed. After successful programming, only the new programmed transmitters will be accepted. Note that an incorrect programming procedure dose not affect the stored codes. 6. After programming, the system can be checked by activating/deactivating the remote locking functions. Programming Procedure - AKA Relearn 03-07 1. Close all doors and fasten the driverââ¬â¢s seat belt to ensure conflicting chimes do not sound during the procedure. 2. Put the key in the ignition. 3. Turn the key from the 2 (OFF) position to the 3 (ON) position. 4. Cycle four times rapidly (within six seconds) between the 2 (OFF) and the 3 (ON) position. Note: The fourth turn must end in the 2 (OFF) position. 5. Within 20 seconds press any button on the remote entry transmitter. Note: If more than 20 seconds have passed you will need to start the procedure over again. 6. Repeat Step 5 to program each additional remote entry transmitter. 7. Turn the ignition to the 3 (ON) position after you have finished programming all remote entry transmitters to exit programming mode. Programming Procedure - AKA Relearn 08-09 Note: Ensure the brake pedal is not depressed during this sequence. 1. Ensure the vehicle is electronically unlocked. 2. Put the key in the ignition. 3. Turn the key from the 1 (off) position to 3 (on). 4. Cycle eight times rapidly (within 10 seconds) between the 1 (off) position and 3 (on). Note: The eighth turn must end in the 3 (on) position. 5. The doors will lock, then unlock, to confirm that the programming mode has been activated. 6. Within 20 seconds press any button on the remote entry transmitter. Note: If more than 20 seconds have passed you will need to start the procedure over again. 7. The doors will lock, then unlock, to confirm that this remote entry transmitter has been programmed. 8. Repeat Step 6 to program each additional remote entry transmitter. 9. Turn the ignition to the 1 (off) position after you have finished programming all of the remote entry transmitters. 10. The doors will lock, then unlock, to confirm that the programming mode has been exited. How-to Program New Keyless Door Lock - hanserus - 10-30-2008 wow thanks dude I'm getting a new key cylinder complete with keyless remote tomorrow so as soon as I get a chance to install it I'll test this and report on the results How-to Program New Keyless Door Lock - paolo - 03-17-2009 awesome write-up How-to Program New Keyless Door Lock - malim - 03-18-2009 hanserus Where are you getting the cylinder from ? Local dealer or Hilbish Ford (US) ?? |
