Exhaust - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Exhaust (/showthread.php?tid=255) |
Exhaust - Scourge - 02-28-2010 Hey All, I finally cracked and picked up an exhaust for my fofo. I grabbed Tetra's old exhaust. Despite being worried that it would be too loud (he has a header and it was rather loud on his car) I'm very happy with it! I'm still running the stock mani-cat and flex, this kit has the high flow cat welded in-line so it bolted right up to the two bolt flange on the flex pipe. The other two sections fit in perfect with a couple clamps and everything lined up right away. There is a Magnaflow resonator welded to the cat and the mid section has a Magnaflow muffler (rear section is just the tail pipe). Overall I'm really impressed with the sound, deep, mellow, and quiet. At idle it's no louder then stock inside the car and right at the tail pipe it's only deeper then stock, no louder. I haven't had it out on the highway yet, but I can't imagine it being loud at cruising speeds. So if you're hesitating on an exhaust upgrade due to concerns of high volume like I was, check out this kit!! -George P.S. I couldn't resist firing the car up with only the mani-cat and flex on it, surprisingly quiet! That cat really makes a huge difference! Exhaust - Spinal - 02-28-2010 you should dyno your car this year and see what the gains are B) Exhaust - Scorcher000 - 03-01-2010 Yes that cat holds a lot back. Wait untill you here my Cossy add on> that suction noise just stepped it up a notch... BAM! Exhaust - tetra - 03-17-2010 Really glad you like it George! |
