Cel Codes? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Cel Codes? (/showthread.php?tid=2885) |
Cel Codes? - SL8RZZX3 - 08-02-2008 Well i finally got my "new-to-me" motor in with the PWSC and it fired up no prob.... Idled for a bit, i touched the throttle and then it sputtered and stalled Threw codes 1504 and 1506, and my code reader doesn't go that high.... Anyone know what these codes mean? Cel Codes? - hardk0re - 08-02-2008 P1504 Idle Air Control Circuit Malfunction P1506 Idle Air Control Overspeed Error Check your connections to the IAC :) I have a spare IAC here if you want to try that... Also: http://www.svtlightnings.com/scantool/ford%20dtc%20codes.htm Cel Codes? - lintlars - 08-06-2008 I also had these and it turned out to be the EGR where it plumbs back into the intake on the firewall side Cel Codes? - NikiterZTS - 08-06-2008 i believe i had 1504 before i think it was damaged rubber hoes on the bottom of the intake manifold Cel Codes? - ZX5focused - 08-06-2008 if i remember correctly, i beleive it may be possible to to install the IAC backwards. might wanna check that. |
