Svt Problem - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Svt Problem (/showthread.php?tid=295) |
Svt Problem - Jmountney1 - 02-18-2010 i noticed an issue today. there is sort of a clunky weird noise coming from front right side of car. its not suspension i think its axial.. :( i can only here it half the time. and it only dose it at slow speed wile turning. appers to do it worse wile turning right. also u kind of have to spin the tires a bit to get it to make the noise. turning traction control on and off doesn't change any thing ether. can any one enlighten me a bit 1. im assuming the axial for a svt is diff than a normal focus 2. has any one ever bought a axial for a svt :blink: best explanation of the nose. is it sounds like i have a full race LSD :D Svt Problem - Gabriel - 02-18-2010 Jmountney1,Feb 17 2010, 04:10 PM Wrote:i noticed an issue today.I don't know what to say , could it be the CV joint or axle as you call it ? If it goes like toc-toc-toc-toc when you turn and also accelerate , that's the one . And it should do it pretty much every time you turn (i don't mean the steering wheel being just a little off the straight , but being turned about half way or when doing a U-turn) . As for the LSD sound , I never had one . Another one could be the bearing starting to go and gives you a short grinding sound only sometimes when you turn , depending which side is worn .Check the wheel for play . Hope this helps . Svt Problem - Jmountney1 - 02-18-2010 yes lol CV joint im gona get it on a hoist tomorrow and look at it. hopefully nuttin to bad Svt Problem - konafocuswrc - 02-18-2010 dealer won't cover it?? i thought you bought it from dealer?? it sounds like cv axle is going bad.. like mine.. Svt Problem - ZX3_2NV - 02-19-2010 I would take it back it wouldn't pass safety with a broken cv. Svt Problem - Jmountney1 - 02-19-2010 i bought it "as is" from the dealer then saftyd it at my buddys shop. so im gessin the dealer is gona do frig all. Svt Problem - Jmountney1 - 02-19-2010 and ive put 4000km on it allready Svt Problem - ZX3_2NV - 02-19-2010 Sorry but they sold it as is for a reason. Svt Problem - Jmountney1 - 02-19-2010 only thing is that when i bought it i was told all it needs was brakes and tires. and it did safty with just brakes and tires. so im assuming i cant try and get the dealer to cover it. Svt Problem - Jmountney1 - 02-19-2010 cars going on hoist tonight. i just got a price on the axial hoping i dont need to replace it but $433.75 for right side Svt Problem - Gabriel - 02-19-2010 If you're not in the money and don't get the noise constantly , I wouldn't hurry . Just take it easy from standing point and try not to accelerate hard through the turns . These things don't just brake , they could knock but keep working for a long time .You might be able to change just the outboard cv joint . That is the part that you see behind the wheel wrapped in a rubber boot . Svt Problem - Jmountney1 - 02-19-2010 so after inspection every thing appears to be ok..?? even my mechanic buddy thinks every things ok and of course i wouldn't make the noise wile he was in the car. but it did do it on the way home :angry: :angry: so i guess i sit tight and if it gets worse i do sum thing abought it. is there any thing inside the tranny/what ever king of diff it has that could be making a noise.. i guess im just a paranoid parent :blink: Svt Problem - Gabriel - 02-19-2010 Jmountney1,Feb 18 2010, 11:13 PM Wrote:is there any thing inside the tranny/what ever king of diff it has that could be making a noise..I don't think so . I can't think of anything else right now . Maybe just checking the transmission fluid level ? Being a new car for you , may have all sorts of strange sounds that you can't diagnose , but wait awhile and they may go away ( or you get used to them :lol: ) , or you may find exactly where they come from . If you're ever coming to Barrie area give me a shout , I'd like to see it . BTW can you post a pic of it ? Svt Problem - ZX3_2NV - 02-19-2010 When something acts up with my cars and it only happens once in a while. I usally swapp cars with my mechanic and let him take mine home for the night and hope he hears it. Svt Problem - NikiterZTS - 02-20-2010 Did you change all the liquieds after purchesing the vehicle? It's just a safe thing to do. Svt Problem - sonic_mikey - 02-20-2010 Gabriel,Feb 18 2010, 02:22 PM Wrote:If you're not in the money and don't get the noise constantly , I wouldn't hurry . Just take it easy from standing point and try not to accelerate hard through the turns . These things don't just brake , they could knock but keep working for a long time .You might be able to change just the outboard cv joint . That is the part that you see behind the wheel wrapped in a rubber boot . +1, one of my profs his dad had a ranger and the transmission would whine in 3rd all the time. The sound started at 40k and the trans went @ 280k......dont want to give any false hope, but Fords will run for a veryyyy long time with a strange noise and nothing happening lol Svt Problem - Jmountney1 - 02-20-2010 Gabriel,Feb 19 2010, 01:41 PM Wrote:Jmountney1,Feb 18 2010, 11:13 PM Wrote:is there any thing inside the tranny/what ever king of diff it has that could be making a noise..I don't think so . I can't think of anything else right now . Maybe just checking the transmission fluid level ? Being a new car for you , may have all sorts of strange sounds that you can't diagnose , but wait awhile and they may go away ( or you get used to them :lol: ) , or you may find exactly where they come from . If you're ever coming to Barrie area give me a shout , I'd like to see it . BTW can you post a pic of it ? i changed the oil but not the transmission fluid. (i plan on doing it). i mean the noise isnt very lowed but you can still hear it. ill post pics up Monday or Tuesday thanks all Svt Problem - Gabriel - 02-21-2010 Jmountney1,Feb 19 2010, 10:09 PM Wrote:It's simple to change the transmission fluid . Just jack up the front , or get up on some ramps , you will find two plugs on the tranny , on underneath and on on the front , toward the radiator . Drop the existing fluid and replace it with 2 qts of fresh one and you're done . You will need a funnel with long flexible neck .Gabriel,Feb 19 2010, 01:41 PM Wrote:Jmountney1,Feb 18 2010, 11:13 PM Wrote:is there any thing inside the tranny/what ever king of diff it has that could be making a noise..I don't think so . I can't think of anything else right now . Maybe just checking the transmission fluid level ? Being a new car for you , may have all sorts of strange sounds that you can't diagnose , but wait awhile and they may go away ( or you get used to them :lol: ) , or you may find exactly where they come from . If you're ever coming to Barrie area give me a shout , I'd like to see it . BTW can you post a pic of it ? |
