Cel Came On - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Cel Came On (/showthread.php?tid=3019) |
Cel Came On - focusonthis_88 - 07-03-2008 So, the CEL came on and the code from the OBDII is P1120 (Throttle Position Sensor out of range). Did anyone get this and how did you fix it? Cel Came On - OAC_Sparky - 07-03-2008 focusonthis_88,Jul 2 2008, 07:03 PM Wrote:So, the CEL came on and the code from the OBDII is P1120 (Throttle Position Sensor out of range).It's exactly what it says. Your TPS is malfunctioning, sooner or later you will need to replace it. Cel Came On - focusonthis_88 - 07-03-2008 OAC_Sparky,Jul 2 2008, 07:06 PM Wrote:focusonthis_88,Jul 2 2008, 07:03 PM Wrote:So, the CEL came on and the code from the OBDII is P1120 (Throttle Position Sensor out of range).It's exactly what it says. Your TPS is malfunctioning, sooner or later you will need to replace it. Where is that sensor located? Cel Came On - malim - 07-03-2008 It is on the TB (throttle body). Left hand side usually and it is black little thing that has a connector and it is right in the beginning of it. Looks something like this ![]() Good luck. Cel Came On - oldeguy - 07-03-2008 focusonthis_88,Jul 2 2008, 08:12 PM Wrote:Sensor is located on the right side of the Throttle Body. As long as you don't have an automatic transmission on a 2000 Zetec, it's a matter of unscrewing the sensor and replacing. The Ford part is around $80.00OAC_Sparky,Jul 2 2008, 07:06 PM Wrote:focusonthis_88,Jul 2 2008, 07:03 PM Wrote:So, the CEL came on and the code from the OBDII is P1120 (Throttle Position Sensor out of range).It's exactly what it says. Your TPS is malfunctioning, sooner or later you will need to replace it. Cel Came On - Flofocus - 07-04-2008 ah, P1120, means the car will self destruct in 15 seconds :P :lol: Let me know if you need help with it. :) Cel Came On - ZTWsquared - 07-04-2008 oldeguy,Jul 3 2008, 07:09 AM Wrote:Sensor is located on the right side of the Throttle Body. As long as you don't have an automatic transmission on a 2000 Zetec, it's a matter of unscrewing the sensor and replacing. The Ford part is around $80.00From a Ford dealer in Ontario the cost including taxes is 113.60 ... I can get the OEM Motorcraft part for you for 65.00 all in (part no. DY871) - a savings of 48.60, or 42% Cel Came On - focusonthis_88 - 07-04-2008 ZTWsquared,Jul 3 2008, 12:14 PM Wrote:oldeguy,Jul 3 2008, 07:09 AM Wrote:Sensor is located on the right side of the Throttle Body. As long as you don't have an automatic transmission on a 2000 Zetec, it's a matter of unscrewing the sensor and replacing. The Ford part is around $80.00From a Ford dealer in Ontario the cost including taxes is 113.60 ... I can get the OEM Motorcraft part for you for 65.00 all in (part no. DY871) - a savings of 48.60, or 42% Ya I found one for 50$. |
