Rpms Jumping All Weird. - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Rpms Jumping All Weird. (/showthread.php?tid=36) Pages:
Rpms Jumping All Weird. - Focus-SE - 04-23-2010 My Rpm's are jumping all weird when im accelerating and the car's noisier than usual. I changed my spark plugs and wires not to long ago and today I had new tires put on so the seals should be good but i'm still getting a bit of vibration. Do I need new Fuel injectors? Rpms Jumping All Weird. - paolo - 04-23-2010 Do you have a CEL Light? if so, it could be a PFE, otherwies, I have no idea man... :unsure: :unsure: Rpms Jumping All Weird. - Focus-SE - 04-23-2010 paolo,Apr 22 2010, 05:32 PM Wrote:Do you have a CEL Light? if so, it could be a PFE, otherwies, I have no idea man... :unsure: :unsure: not sure what that is, but none of the engine lights are on the dash. Rpms Jumping All Weird. - OAC_Sparky - 04-23-2010 TPS Rpms Jumping All Weird. - Focus-SE - 04-23-2010 OAC_Sparky,Apr 22 2010, 08:22 PM Wrote:TPS are those easy to install? Rpms Jumping All Weird. - paolo - 04-24-2010 tps would have been my 2nd guess Rpms Jumping All Weird. - Focus-SE - 04-24-2010 paolo,Apr 23 2010, 12:57 PM Wrote:tps would have been my 2nd guess I was quoted 32 bucks for one TPS at Part source today. Rpms Jumping All Weird. - paolo - 04-24-2010 Focus-SE,Apr 23 2010, 05: Wrote:I was quoted 32 bucks for one TPS at Part source today. thats like 1/4 of what ford charges, no? Rpms Jumping All Weird. - Focus-SE - 04-27-2010 Quote:thats like 1/4 of what ford charges, no? probably Ford dealerships here charge an arm and a leg for parts. Rpms Jumping All Weird. - paolo - 04-27-2010 get ready to start cutting off your limbs bro. :P :P Rpms Jumping All Weird. - Focus-SE - 04-27-2010 is this where TPS is located? Rpms Jumping All Weird. - Focus-SE - 04-27-2010 Paolo forgot to mention.. Just yesterday I was climbing up the escarpment and the yellow light with the exclamation point went on, then when i got to the top 5 minutes later.. the light went off. Rpms Jumping All Weird. - dBlast - 04-27-2010 The TPS is where the throttle cable attaches to the throttlebody (top left corner of the "P"). The area that you are highlighting in the picture is the MAF. The jumping idle can also be caused by a vacuum leak, faulty wires connecting to the MAF, faulty IAC valve, or many other reasons. Before you start replacing every part, check for a vacuum leak first. Rpms Jumping All Weird. - paolo - 04-27-2010 The Yellow light with the Exclamation mark POSSIBLY could mean a cooloant system leak or a warning the engine temp is too high? I had that happen to me once, i was lucky, turned off the car, let it cool off, i was oly 5 mins away, so when i started her up again, i made it home safely before the temp could rise too high.. took it in to ford in the am, they fixed her up good. Rpms Jumping All Weird. - sonic_mikey - 04-28-2010 The (!) mark also indicates an automatic trans axle problem AND cooling issue. In my SVT, if i dont start it first try, that lil bastered pops up lol Rpms Jumping All Weird. - Focus-SE - 04-30-2010 sonic_mikey,Apr 27 2010, 05:22 PM Wrote:The (!) mark also indicates an automatic trans axle problem AND cooling issue. In my SVT, if i dont start it first try, that lil bastered pops up lol so this means I have two problems. with the cooling and the air RE: Rpms Jumping All Weird. - Focus-SE - 05-04-2010 Well I didn't seem to find any vacuum leak so I decided to start figuring what the hell's wrong by starting with the tps. now from the picture, there doesn't seem to be anything physically wrong with the tps.. I went down to canadiantire, they didnt have a throttle position sensor so I go to partsource.. they ended up giving me the wrong throttle sensor.. (didn't fit) so I go back the guy i dealt with wasn't there at the counter, so the other guy apologized gave me a refund and told me it wasnt in stock. So I go to another Canadian tire.. they tell me the previous location I went to was the only one in Hamilton with one in stock.. which was ridiculous cause they told me they didn't have any.. by the time all of this happened it was too late to call the dealerships for a price quote.. both crappy tire and part source quoted me 70-75 for the TPS.. the wrong one I bought today was 35 bucks.. god knows what the dealership wants.. RE: Rpms Jumping All Weird. - OAC_Sparky - 05-04-2010 (05-04-2010, 01:13 PM)Focus-SE Wrote: Well I didn't seem to find any vacuum leak so I decided to start figuring what the hell's wrong by starting with the tps.There is a test method to check the TPS before you replace it. I'll try to find the prcedure and post it. RE: Rpms Jumping All Weird. - Flofocus - 05-04-2010 i'd check for a vacuum leak 1st also. There is the wires going to your coil pack that be be brittle and causing you the same issues. The coil pack is the box where your plug wires plug into. Check the connector in front of it. Pull the it out and inspect the wires.... This is what mine looked like when I was having issues: RE: Rpms Jumping All Weird. - Focus-SE - 05-05-2010 k thanks, I'll give the coil pack a look over before I go out buying anything |
