Gas Gauge Issue - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Gas Gauge Issue (/showthread.php?tid=3834) |
Gas Gauge Issue - NoiSeeVT - 02-19-2008 Well the last few times Ive filled up the SVTF the gas gauge never will go to full, this last time it only went to 3/4. I was just wondering if anybody has had a similar issue so when I take it to the dealer, I can give them a hint. Just on a side note I always fill up with Shell 91 octane (I had a cavalier that use to have problems with PetroC gas). Thanks David Gas Gauge Issue - naz - 02-19-2008 on my focus same thing happened.. it was an issue with the fuel gauge sender unit. eventually my gauge went completely (ie read close to empty when i pumped in 10 gallons) and that's when i had it replaced Gas Gauge Issue - 02ztsian - 02-19-2008 I am sure you are aware but just in case you aren't the Focus has a habit of not filling the tank fully. I can always add a few extra litres after the pump clicks off. It's a common issue with the Focus and I can't see the SVT being any different. Gas Gauge Issue - Flofocus - 02-19-2008 naz,Feb 18 2008, 12:30 PM Wrote:on my focus same thing happened.. it was an issue with the fuel gauge sender unit. eventually my gauge went completely (ie read close to empty when i pumped in 10 gallons) and that's when i had it replaced Yup, had the same issue, my fuel sending unit was repaired under warranty though. Gas Gauge Issue - NefCanuck - 02-19-2008 I'll echo what others have said as it's almost certainly your fuel sending unit, but just be careful b/c the sending unit & the fuel pump are closely tied together, you'll probably be better off replacing both at once esp. if your car is of higher mileage... NefCanuck Gas Gauge Issue - NoiSeeVT - 02-20-2008 Its only got 45k, and its still uner warrenty so Im sure they wont do both, but Thanks for the input off to the Dealer. David |
