Oil Pressure Gauge *pics Updated* - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Oil Pressure Gauge *pics Updated* (/showthread.php?tid=3857) |
Oil Pressure Gauge *pics Updated* - girard.k - 02-14-2008 has anyone installed an oil pressure gauge in here they can help me out with...I have a glowshift gauge and sender unit... i believe i need an oil filter adapter, like in step 5. Tell me wut you think... Thanks for your help guys... Oil Pressure Gauge *pics Updated* - hardk0re - 02-14-2008 how big is the sender unit? I put a few in, all the electronic ones were a pain because the senders where HUGE! Oil Pressure Gauge *pics Updated* - naz - 02-14-2008 girard.k,Feb 13 2008, 06:37 PM Wrote:has anyone installed an oil pressure gauge in here they can help me out with...I have a glowshift gauge and sender unit... i have a mechanical gauge in my car. i think you should use some of that teflon tape stuff on the threads when you put the fitting into the block, and when you put the fitting into the gauge. the key is that you don't want any oil leaking out! you have to figure out which oil galley to tap into.. usually there's a bolt that you can back out, and then replace with the fitting that goes to the sender (electric) or the gauge (mech). sorry i can't help you with where to tap, i'm using a sube not a focus. Oil Pressure Gauge *pics Updated* - ZX3_2NV - 02-15-2008 I also have one, was a B!TCH after it was installed I cracked the line going to the sending unit and dripped oil everywhere all they way to the shop thankfully it was pretty close. So becareful and make sure its very secure. Oil Pressure Gauge *pics Updated* - girard.k - 02-15-2008 im gonna post some pics, and maybe you can help me out, I do have the huge sender unit... Oil Pressure Gauge *pics Updated* - girard.k - 02-21-2008 bumpity bump bump Oil Pressure Gauge *pics Updated* - ZX5focused - 02-21-2008 if i remember correctly, (going off my friends escort zx2 zetec, same block, dif head) there is an oil hole tapped on the back of the motor, under the intake manifold. judging by the size of the sender, i dunno if it will fit. ill wait for flo, hardkore or zx3 2nv to chime in on this since they this motor better. but on my friends motor, thats where he ran his feed line from to the turbo. Oil Pressure Gauge *pics Updated* - Flofocus - 02-21-2008 Look slike it *May* fit where zx5 is saying. Pretty sure you will need a 'T' Tap and screw that in the back of the block... This is a pic of teh spot...my stock sensor is still plugged in because I used the t tap. Oil Pressure Gauge *pics Updated* - 02ztsian - 02-21-2008 I think this is what you need... http://www.glowshiftdirect.com/index.asp?P...PROD&ProdID=199 Oil Pressure Gauge *pics Updated* - Flofocus - 02-22-2008 02ztsian,Feb 21 2008, 09:44 AM Wrote:I think this is what you need... Fawkin neat :) Oil Pressure Gauge *pics Updated* - ZX5focused - 02-22-2008 Flofocus,Feb 21 2008, 09:35 AM Wrote:02ztsian,Feb 21 2008, 09:44 AM Wrote:I think this is what you need... i know what im getting if i ever go turbo!!! Oil Pressure Gauge *pics Updated* - ZX3_2NV - 02-22-2008 wow that is pretty cool i never knew taht exsisted that would prob be the best route Oil Pressure Gauge *pics Updated* - girard.k - 02-22-2008 02ztsian,Feb 21 2008, 08:44 AM Wrote:I think this is what you need... yeah i knew about the part but i wanted to avoid buying it if i could but for convenience sake thats what im gonna do...and i continually debate turbo... but is it the 18mm thread? Oil Pressure Gauge *pics Updated* - naz - 02-22-2008 that's an interesting product. that design is really similar to the oil cooler that the WRX uses. same exact idea.. a ring that goes between the block and the oil filter.. except instead of a gauge sender unit there are hardlines going to and from the rest of the cooling system, so coolant flows through and cools the oil as it goes through the filter someone should retrofit that setup onto other cars.. it could be a cheap alternative to an aftermarket oil cooler Oil Pressure Gauge *pics Updated* - ZX5focused - 02-22-2008 naz,Feb 21 2008, 09:35 PM Wrote:that's an interesting product. its actually a part out of their oil cooler kit that they sell elsewhere on the site Oil Pressure Gauge *pics Updated* - ZED_not_zee - 02-22-2008 OMG it's a sandwich adapter.. they've been around since the oil filter! this by far the best way to: ad an oil cooler ad an oil temp or presure guage or relocate an oil filter for easy changing... like mine is going where the stock air box should be using somthing like this... http://www.jcwhitney.com/webapp/wcs/stores...catalogId=10101 Oil Pressure Gauge *pics Updated* - girard.k - 02-23-2008 does anyone know the thread size of the oil filter? I need to choose which sandwich i need to buy!!! Oil Pressure Gauge *pics Updated* - hardk0re - 02-23-2008 I have mocal oil filter relocation adapters if your interested in going that route. Take that to PM if your interested. I believe the filter thread is 3/4"UNF Oil Pressure Gauge *pics Updated* - girard.k - 02-26-2008 I believe the filter thread is 3/4"UNF [right][snapback]258620[/snapback][/right] [/quote] can i get a second on the thread size, i dont really need a relocation...thanks hardk0re Oil Pressure Gauge *pics Updated* - faster_than_u - 02-26-2008 i also want to know the thread size |
