Potetial Transmission Issue - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Potetial Transmission Issue (/showthread.php?tid=3872) |
Potetial Transmission Issue - ThraxXx - 02-11-2008 Hey All, Been a while since I posted here but figured I would see if any of you had this problem. Recently when I put my focus in reverse and backup the car makes a grinding sound. The shifter doesn't feel like its trying to pop out of gear or anything. Have any of you had this problem before? Car is a Focus LX 2.0L SPI with a 5 speed Manual Tranny. All stock no mods. Potetial Transmission Issue - j3rt - 02-12-2008 worn brake pads dragging? or a bearing. Potetial Transmission Issue - ThraxXx - 02-12-2008 It doesn't happen when moving forward though...could this still be a brake pad issue. When you say Bearing...you mean wheel bearing right? Potetial Transmission Issue - naz - 02-12-2008 i'm guessing three things rear wheel bearing, rear brakes (which you guys have already said) or a parking brake that needs adjusting. if it was a tranny issue it would more than likely be difficulty/grinding getting into reverse, clunking, or popping out of gear. good thing it isn't any of these, because tranny would be $$$ other stuff is not so bad Potetial Transmission Issue - ThraxXx - 02-12-2008 I am starting to Lean towards parking brake. Gonna get that checked out and see if it fixes the issue. Thanks for the help. |
