3000w Power Inverter - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Classifieds (//www.focuscanada.net/forum/forumdisplay.php?fid=5) +--- Forum: Sell Items (//www.focuscanada.net/forum/forumdisplay.php?fid=26) +--- Thread: 3000w Power Inverter (/showthread.php?tid=3953) |
3000w Power Inverter - Chromey - 01-28-2008 Used Condition, Works 100% Lowest ill go is 200$ Now 150$ Now 120$$ Plus shipping. http://www.4lots.com/index.asp?PageA...PROD&ProdID=31 Specifications Inverters: Portawattz 3000 Specifications Model: Portawattz 3000 Electrical Specifications Maximum continuous Power 2500W Surge capability 5000W / 3000W No load current draw <0.6a Peak efficiency 90% Output waveform modified sine wave Output frequency 60Hz quartz crystal controlled Output voltage 115VAC RMS +/- 5% Input voltage range 10 to 15 VDC Mechanical Specifications Operating temperature range 0C to 40C Internal Fuse not user replaceable Weight 20 lb / 9 Kg Dimensions / L X W X H 18.5" X 8.0" X 6.25" / 47cm X 23cm X 15.9cm AC receptacles 2 grounded outlets with dedicated 15A breakers. 3000w Power Inverter - lowblackdub - 02-09-2008 Oooh... this would be perfect for the cabin. We're running 12V deep cycles - sure would be nice to have AC... 3000w Power Inverter - Chromey - 02-09-2008 lowblackdub,Feb 8 2008, 10:45 PM Wrote:Oooh... this would be perfect for the cabin. We're running 12V deep cycles - sure would be nice to have AC...make the dream come alive... 3000w Power Inverter - Chromey - 02-17-2008 bump 3000w Power Inverter - Chromey - 03-16-2008 bump |
