How Much Does End Links Cost? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: How Much Does End Links Cost? (/showthread.php?tid=3980) |
How Much Does End Links Cost? - paolo - 01-24-2008 Dealer said i needed my end links replaced when i had my last oil change, how much do u think these cost on a 2002 focus 5 speed manual standard transmission? should i go to the dealor or the local brown guy's auto shop? (no offence to brown people) How Much Does End Links Cost? - naz - 01-24-2008 end links.. as in the brackets that bolt the swaybar to the car? they shouldn't be very expensive. the only reason to replace end links that i can see is corrosion, and that could make it a PITA to remove them. i recommend that you go to a shop that you trust, who you know will be patient getting the rusted bolts out (they will prob snap and have to be tapped out) i;m guessing labor will be a lot more than the parts How Much Does End Links Cost? - Flofocus - 01-24-2008 Can't recall off the top of my head but I think mine were $16.each. One side wasn't a problem, but like naz said, the other was rusted to s*** and I had to pay the garage 1/2 hour labour to get the 1 bolt off. :angry: How Much Does End Links Cost? - ZX3_2NV - 01-24-2008 If you need a shop ive gotten mine done already at P R Performance was an easy intall i had zero rust Check http://www.prperformance.ca for shop details How Much Does End Links Cost? - naz - 01-24-2008 ZX3_2NV,Jan 23 2008, 08:40 PM Wrote:was an easy intall i had zero rust that's the thing.. the OP unfortunately almost certainly has rust... :( How Much Does End Links Cost? - Canadian ST - 01-24-2008 If you need the rear end links you can have my old ones from my 07, When I put on the roush bar I used the endlinks that came with the package. Let me know. How Much Does End Links Cost? - 02ztsian - 01-24-2008 Spend the extra money and pick up the Moog endlinks. Guess which one is the Moog? ![]() And greasable to boot. I think Auto Value sells them for around $35 each. How Much Does End Links Cost? - paolo - 01-24-2008 i also had new springs installed recently, so they HAD to remove my end links and re-install them... probaly not so much rust but worn out How Much Does End Links Cost? - snorcus - 01-24-2008 The way we do them, if your taking them off cause they are no good, we just put the impact on them and snap the bolt . Takes two min and they are off. I would go with either a moog one or the NAPA good ones bc they ususally have a lifetime warranty. How Much Does End Links Cost? - snorcus - 01-25-2008 just remember to grease them |
