Seafoam - Printable Version
+-- Forum: Marketplace (//www.focuscanada.net/forum/forumdisplay.php?fid=8)
+--- Forum: Product Reviews (//www.focuscanada.net/forum/forumdisplay.php?fid=50)
+--- Thread: Seafoam (/showthread.php?tid=4453)
Seafoam - oldeguy - 10-30-2007
I tried Seafoam, an "engine cleaner" to see if it would help clear up a small problem I had. The engine at idle would be erratic, going up and down, and sometimes stay too high. Cleaned the MAF sensor first, that helped a little. Tried Seafoam, pored some, 2-3 ounces, into a vacuum line. Let it sit for ten minutes, started up the car, and for a minute, I thought I had blown something up. The exhaust was very white and lots of smoke for a few minutes. Apparently, this means the stuff is working. Since then, the idle is steady, at the proper speed, and I've noticed a better all round driveability to the car. I'm recommending this product to help keep our engines running smoothly. :lol:
Seafoam - ANTHONYD - 10-30-2007
where did you find it?
I've heard this stuff is really good!
ANTHONYD,Oct 30 2007, 08:28 AM Wrote:where did you find it?
[right][snapback]251967[/snapback][/right]
Carquest.
Seafoam - NikiterZTS - 10-30-2007
yes i tried it ones...it was good stuff
p.s. what did u use to clean the MAF?
would break cleaner work?
Seafoam - oldeguy - 10-31-2007
NikiterZTS,Oct 30 2007, 09:41 AM Wrote:yes i tried it ones...it was good stuff
[right][snapback]251973[/snapback][/right]
MAF sensor cleaner.
I'm not sure about the Brake Cleaner.
Seafoam - Flofocus - 10-31-2007
MAF sensor cleaner.
[right][snapback]251974[/snapback][/right]
I use that ABS sensor safe brake cleaner to clean my maf.
Seafoam - NikiterZTS - 10-31-2007
MAF sensor cleaner.
[right][snapback]251976[/snapback][/right]
thats exectly what i have.....i might give it a try.......so basicly you just spray some on? no rubbing or anything right?
MAF sensor cleaner.
[right][snapback]251978[/snapback][/right]
no rubbin' allowed.
you dont want to touch anyting in the MAF, just spray it down good and let it dry. It shouldnt be THAt dirty anyways...I know mine isn't and it sits 1 foot off the ground with a dirty K&N letting all sorts of crap in.
Seafoam - j3rt - 10-31-2007
I read a number of funny stories on the Saab site about this stuff. Guys using that stuff for the cars first time after 10 yrs and they end up fogging the neighborhood. Some once said to never use it near your house, go to a mall or the country.
Seafoam - meford4u - 10-31-2007
a carb cleaner is what you should use.
