Little Help? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Little Help? (/showthread.php?tid=4459) |
Little Help? - Someguy_ca - 10-29-2007 Anyone know where this hose is meant to go? ![]() Little Help? - SL8RZZX3 - 10-29-2007 A little more info might help! lol what is it you are doing? are you installing an intake? Do you mean the hose from the top of the valve cover? it goes into the back of the airbox. if you're switching to an intake, there should be a spot for that hose to attach to, if not then just attach a breather filter Little Help? - Someguy_ca - 10-29-2007 Ya it's the intake... But I had a bit of a coolant geizer, and I'm trying to track it down. Edit... Found the problem. It seems the half wit mechanic from the dealership somehow cut a heater hose, while replacing the shifter parts. Little Help? - hardk0re - 10-29-2007 I was going to ask why coolant was everywhere :P Little Help? - Someguy_ca - 10-29-2007 hardk0re,Oct 28 2007, 08:07 PM Wrote:I was going to ask why coolant was everywhere :P Ya... Problem #2 for this car, and 5th time in two weeks that I've had to figure out wtf was wrong, or how to fix it. Little Help? - Alec Brandon - 10-29-2007 Quote:Ya... Problem #2 for this car, and 5th time in two weeks that I've had to figure out wtf was wrong, or how to fix it. Don't blame the car for human error! Little Help? - FocusGuy7476 - 10-30-2007 the hose goes into your intake on the side that faces the engine, there should be a hole in the intake box that the hose just plugs into. |
