Uh Oh~wheel Stud Broken.. - Printable Version
+--- Thread: Uh Oh~wheel Stud Broken.. (/showthread.php?tid=4609)
Uh Oh~wheel Stud Broken.. - konafocuswrc - 10-07-2007
recieved new lug nuts yesterday, black and very light..
when removing wheel locks, there was good portion of key slot left on wheel key, so i cut it in half and started to remove wheel nuts,everything came out good except the rear one..
now i broke 1 stud out of 4..thank you very much canadian tire..
is it really dangerous to drive only 3 studs??
how hard is it to replace broken stud??
Uh Oh~wheel Stud Broken.. - Oscar The Grouch - 10-07-2007
konafocuswrc,Oct 6 2007, 09:57 PM Wrote:recieved new lug nuts yesterday, black and very light..
[right][snapback]250312[/snapback][/right]
Its not really hard to replace. Get a hammer and a punch to knock the broken one out. Then hammer a new one in.
cool~so only place i can get stud is dealer???
konafocuswrc,Oct 6 2007, 10:12 PM Wrote:cool~so only place i can get stud is dealer???
[right][snapback]250315[/snapback][/right]
Crappy Trash has them. Pretty much any auto parts store should have them.
Uh Oh~wheel Stud Broken.. - ZED_not_zee - 10-08-2007
yea this is like the most common issue with the studs mounted in the drums... use a little bit of JB cold weld to hold the stud in tight now that the hole has been stripped
Uh Oh~wheel Stud Broken.. - konafocuswrc - 10-08-2007
hole is not stripped..
stud is broken..
i need to get 30mm socket now..
but where is the nearest location..sigh..
I dunno where to source that socket in your area,,, I would look in a industrial supply store here called checker industrial or car quest usually carries impact large format sockets...
Uh Oh~wheel Stud Broken.. - konafocuswrc - 10-10-2007
it is all fixed now..
was really easy job..
30mm nut off, released ebrake, wiggle brake hub, hammer broken stud couple times, new stud in, blah blah, put all back in, test drive, done..
only took me 30 mins..
