Bad Enough To Do - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Bad Enough To Do (/showthread.php?tid=4624) |
Bad Enough To Do - oldeguy - 10-05-2007 Finally the front axle is bad enough to fix, making noises most of the time, instead of occasionally, does anyone know how much a 32 mm socket will be to purchase? Bad Enough To Do - OAC_Sparky - 10-05-2007 oldeguy,Oct 4 2007, 03:53 PM Wrote:Finally the front axle is bad enough to fix, making noises most of the time, instead of occasionally, does anyone know how much a 32 mm socket will be to purchase?For the amount you'll use it, try to buy one from Princess Auto. Bad Enough To Do - oldeguy - 10-09-2007 Done. Bought the socket at Carquest. Cost $15.00 So, if anybody ever needs one, for a 00-04, let me know Bad Enough To Do - konafocuswrc - 10-09-2007 32mm?? not 30mm?? that is what spindle nut is right?? front and rear is different i guess?? Bad Enough To Do - Flofocus - 10-09-2007 front and rear is different. so dumb. Bad Enough To Do - oldeguy - 10-09-2007 Flofocus,Oct 9 2007, 08:38 AM Wrote:front and rear is different. so dumb.Not if Ford has shares in a tool manufacturer :rolleyes: I guess I'll be buying that one soon..... :( |
