Re-flash Of Ecu - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Re-flash Of Ecu (/showthread.php?tid=4713) |
Re-flash Of Ecu - Alec Brandon - 09-21-2007 The the ECU is re-flashed with a new program should the battery be disconnected afterwards to reset things and allow the system to re-learn everything or is that not required? Re-flash Of Ecu - Gravter - 09-21-2007 I'm thinking that by flashing your ECU would reset it, but I could be wrong. so, why not just disconnect the battery and be safe :ph34r: Re-flash Of Ecu - Mason - 09-21-2007 Gravter,Sep 20 2007, 09:55 PM Wrote:I'm thinking that by flashing your ECU would reset it, but I could be wrong. Flashing the ECU should remove all "Learned" settings and leave the car ready to learn again. |
