3m Head Light Kit - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Off Topic (//www.focuscanada.net/forum/forumdisplay.php?fid=16) +--- Thread: 3m Head Light Kit (/showthread.php?tid=480) |
3m Head Light Kit - Scorcher000 - 01-07-2010 Where can I buy one. I've had trouble trying to find one in stores. 3m Head Light Kit - Focus man. Focus. - 01-07-2010 The polishing kit? I have the bottle of polish here at home. Its the stuff that you do not need to sand the lens. You can use whatever you need. 3m Head Light Kit - reldridge - 01-07-2010 This? I've seen it at some Canadian Tire stores... Check NAPA as well, they can probably order it for you. 3m Head Light Kit - Oscar The Grouch - 01-07-2010 Meguiar's Plast-X works good too. 3m Head Light Kit - Scorcher000 - 01-07-2010 I found it at NAPA... I really wanted the polishing disk and pad but the kit was usefully for a project im working on. Thnx for the responces. FYI buy a sanding block with 2500 grit paper cause the 800grit paper and 3000grit foam disk do a terrible job to get the 500 grit marks out. Nough said. 3m Head Light Kit - Focus man. Focus. - 01-07-2010 Soooooo, what are you doing????? |
